Squeaking Noise
Squeaking Noise
Hey Ive got an 88' 2.8L Camaro.
The other day when I started it up I noticed a little squeaking noise under the hood. I popped the hood and couldnt exactly pinpoint the noise but im pretty sure its the fan belt.
The weird thing about it is the squeaking stops after its been ran for a while. Whether its in park, neutral, reverse or drive it still squeaks at idle speed.
Its annoying as hell and can be embarassing.
Ive heard maybe belt replacment or some fan belt lube? I dont know
Car: 1986 Firebird
Engine: 2.8 V6
Re: Squeaking Noise
If it goes away after a while, but still squeaks at idle, it's probably a bearing- either from the water pump, power steering pump, alternator.
To see if the belt needs to be replaced, look at your tensioner for the max/min arrows; the arrow for the belt should be between the "min" and "max" arrows. If it's at an edge, then yes, the belt is too loose and should be replaced.
But my guess is a bad water pump. Are you leaking coolant?
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: Squeaking Noise
I had this issue ended up being a bad idler pulley.
BTW everytime I see your screen name It keep's reminding me of the song Hard in the paint By Wocka Flocka Flame and the song get's stuck in my head
Re: Squeaking Noise
Re: Squeaking Noise
sjorgens
10-01-2015 07:54 PM
