a couple questions!!!
Car: 1990 camaro rs 3.1 v6
Engine: 3.1 v6
i have a 90 rs with the 3.1 v6 also its a automatic, now im thinking about putting in a b&m megashifter which one would i need? what tranny do i have? and how would i go about installing it?
Engine: 3.1 v6
Re: a couple questions!!!
does that come with install instructions or how is it done is it a quick change or a real pita?
Car: 1986 trans am
Engine: goodwrench 350, 4 bolt main.
easy to install. about an hour .out with the center console, unbolt old shifter , disconnect and pull out old shift cable, run new cable. bolt new shifter . adjust cable. i had a few probs with the new cable bracket, but for the most part it is just a r&r job. you may also have to play with how the plate fits on your console but if you have any probs pm me and i will try to help. i can give you some tips on that cable bracket aswell
