1986 2.8 mechanical temperature guage hook up
I am wanting to put a mechanical temperature guage on my 1986 2.8l camaro. Where is this location at?
Also if you happen to know how to hook up mechanical oil pressure guage.
Thanks so much.
Kyle
Thanks so much.
Kyle
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 1986 2.8 mechanical temperature guage hook up
The coolant temp unit is in the front of the driver's side head. The oil pressure unit is the single wire one down by the oil filter. Don't touch either one of the 2-wire units, the oil pressure switch and the coolant temp sensor. You're looking for the single-wire ones.
