Nitrous Devastation!
Old 10-12-2010, 05:31 PM
  #151
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Nitrous Devastation!
Took a second look at my numbers and IDK where my head was when I did the altitude correction. The first run on 6psi would have been 13.97 not 14.2 and the run when it poped would have been 13.2 not 13.4. So I was a little faster than I thought.
Old 10-12-2010, 05:34 PM
  #152
project89's Avatar
those numbers are much better i knoew there was no way in hell the car was that slow with that much n20 and boost
Old 10-12-2010, 05:39 PM
  #153
bl85c's Avatar
Car: '85 maro
I think it was still too slow on nitrous. Even having it ramp up the way I did something just doesn't add up.
Old 10-12-2010, 05:41 PM
  #154
project89's Avatar
leaky ex valves more then likley, i got those heads apart and started on them, some of the valve seats on the ex side didnt look to good
Old 10-12-2010, 05:44 PM
  #155
bl85c's Avatar
Car: '85 maro
It got beat on near the end that's for sure! I beat on it on the street too and it just wouldn't quit. Till I got to the track anyway...
Old 10-12-2010, 05:46 PM
  #156
project89's Avatar
lol yeah it held up though had it not been for that one lean spot ud still be beating the crap out of it
Old 10-12-2010, 06:25 PM
  #157
firstfirebird's Avatar
I have found that ALL 660's are hard on exh valves. I can't tell you how many of them have been through my surface grinder lol - even low mileage 3500's!
Old 10-12-2010, 08:05 PM
  #158
bl85c's Avatar
Car: '85 maro
When I put 3x00 springs on it I found out it didn't have valvestem seals on the exhaust side, I think in an attempt to keep them cooler. Had to fix that so I wouldn't have oil burning in the exhaust screwing with the turbo.
Old 10-12-2010, 08:47 PM
  #159
project89's Avatar
his looked good but u could see the carbon building up on them i suspect someone did the seats and then replaced the guides as i found new guides installed and the valves werent 100% true to the seats
im pretty sure its due to the design of the ex port under the seat that causes the engines to be hard on the valve seats but i could be wrong
Old 04-19-2012, 09:45 PM
  #160
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
I want to see shrapnel pictures. :-)
Old 05-30-2012, 04:27 PM
  #161
minigunz's Avatar
Car: 1992 firebird
Engine: 3.1.... soon to be... bigger.
Transmission: 700r4, looking for t5
Axle/Gears: I havent a clue.
Turbos AND nitrous!?? This guy is f-ing crazy.. Lol. Hope the clutch doesent chop his foot off so I guess it would be ok to run a 75 shot in my stock 3.1? Lol
Old 05-31-2012, 01:56 PM
  #162
bl85c's Avatar
Car: '85 maro
Clutch? BTW this has been done and over with for a few years...
Old 06-01-2012, 08:49 AM
  #163
minigunz's Avatar
Car: 1992 firebird
I know, I was jus trying to make a joke lol
CarGuyDennis
137
12-06-2016 11:02 PM
anesthes
09-18-2015 12:34 PM
NastyEngines
Group Purchases
09-08-2015 10:14 AM
FlyinLow89
11-12-2001 02:35 AM
vortech305
03-30-2001 12:21 PM
Quick Reply: Nitrous Devastation!
