BELT HELP
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
BELT HELP
I have a 1992 pontaic 3.1 i took out the A.I.R system and put i deletion pulley there and today i was driving and heard a loud and banging like i ran over something. the AIR deletion pulley cracked and broke under the stress so does anyone know of a smaller belt i can run because i can't afford a other pulley and i need my car
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: BELT HELP
Dayco Serpentine Belt
Part No.</B> 5060923 . It is for my 2.8 without air pump . Also this is if you have A/C . If not you will need a shorter belt .
1 Post
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: BELT HELP
if push come to shove, wrap a string around the pulleys as the belt would be routed. mark it, remove and measure (subtract an inch or so to give the tensioner something to put tension on). go to the parts store and tell them you need a serp. belt xx inches long. Might take some persuading with todays parts store people. but, they can find it!!
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: BELT HELP
Advance Auto: Drive-Rite 915K6 for A/C systems, 815K6 for cars without... These are non-AIR belts... Delete all your AIR brackets as well as that junk pulley to save weight.
Car: 1992 firebird
Engine: V6
Re: BELT HELP
oo man its even more room then before lol i kick that deletion pulley to the curb
