Stock 2.8 oil capacity
1 Post
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Hi guys,
So my manual says 4.5 quarts of oil in a 2.8. So i fill the oil filter and put four quarts in. Well I check my oil and it's hard to tell where it is exactly but it's past the full mark. Is 4.5 right, am I blind, what's going on?????
Car: 1987 Pontiac Firebird
Engine: 2.8
Transmission: t5
Axle/Gears: not low enough
Re: Stock 2.8 oil capacity
no, I think that will be ok if its just a little past full, it wont hurt it none
1 Post
no it's like 3-4 inches past full. i checked it like 8 times and i'm still not sure whats going on
Car: 91' bird(WS6>>305TBI), 82'Regal
Did u drain the oil out of the pan when you changed the oil?
1 Post
yeah, i had the whole pan off, had to replace the oil pump. trust me it was empty. The car seems to be running fine, just don't wanna chance anything. But I'm afraid to just drain some oil out when i supposedly put in what it's supposed to have. And no my oil pan doesn't have any dents either
Thanks for the help guys
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
It depends what size oil filter you use. When the 2.8 MPFI V6 was introduced in the third generation F body in 1985 the standard oil filter listed in the manuals was the AC Delco PF47 and the oil capacity was listed at 4 quarts. Around 1988 GM began using the long flow PF51, and later the updated PF52, containing an anti drain back valve, on the the 2.8. The long flow filter holds an exra half a quart of oil. If your using the PF 52 or any equivalent oil filter then the oil capacity should be 4.5 quarts. If you still using the shorter PF47 or an equivalent, then its 4 quarts.
ambainb
04-25-2016 09:21 PM
Navy8125
08-21-2015 09:32 AM
