89 camaro rainy day blues
Car: 84 camaro berlinetta
Engine: 2.8 V6
Transmission: 700 r4
ok so it seems like ever time it rains heavy my car starts hesitating jerking and what not is this an ignition problem i thought the distributor got wet on the inside or something i dnt knw wat it could be help me out v6ers
Re: 89 camaro rainy day blues
There is a gasket between the cap and the distributor body that could be bad. It could also be a wire shorting out. I had a similar issue and it was the plug wire on the second cylinder back on the passenger side. The boot was being eaten by the heat from the EGR pipe. I would check both of these then move onto other electrical components that see a lot of water.
Engine: 2.8 V6
i didnt even knw there was a gasket there hmm thx 'll look n to that
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There isn't. At least there is no gasket on the 3 HEI dizzy's I've seen and the 3 caps I have.
Check your wires. These wires have enough problems on their own without being wet. There is a reason why one of the steps to troubleshooting a misfire is to spray the ignition wires with a spray bottle.
Huh that's odd, mine sure had one.
Engine: 2.8 V6
The cap and rotor are only like 30 bucks to replace, not sure on the gasket. It might come with the cap or you may have to get it separate. As far as the coil goes I would check it, this can be done with either a volt meter or your local parts store should be able to test it.
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Well my dist. doesnt have a gasket, but there is a hood seal along the top of the firewall.
Engine: 2.8 V6
I still haven't got around to change it yet but it seems to be running pretty good now that it's dry should i still change it?
Linson
08-21-2015 02:12 PM
