Is a Mallory 4569201 Unilite Dizzy compatible with a Mallory 6852 Ignition Box?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1985 Camaro Sport Coupe
Engine: 2.8 - Bored/Stroked, Pacesetters
Transmission: 5 spd Manual
Axle/Gears: Stock
So, I have a Mallory #4569201 Unilite Distributor and a Mallory #6852M HyFire VI-A Digital CD Ignition Box. Anybody know if they are compatible with an '85 FI 2.8 and each other? Per Summit Racing the Dizzy is compatible with the motor ( http://www.summitracing.com/parts/MAA-4569201 ) and the Ignition box ( http://www.summitracing.com/parts/MAA-6852M ) is compatible with the motor and the dizzy.
The Mallory dizzy gear appears to be differen't from the stock unit. I attempted to drop it in for initial fitment but because of the gear it doesn't exactly work and is not a Plug and Play install. Can I swap anything from the stock dizzy (Meaning the gear??) to make the Mallory fit?
Any wisdom would be appreciated and make my life a whole lot easier!
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Scott
Scott
Axle/Gears: Stock
Re: Is a Mallory 4569201 Unilite Dizzy compatible with a Mallory 6852 Ignition Box?
Anybody?
Axle/Gears: Stock
Desperate here....
Axle/Gears: Stock
bump
Axle/Gears: Stock
bump
1 Post
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
try getting a hold of the manufacturer. They'll be able to tell you exactly what you need to know.
Axle/Gears: Stock
Yeah, that's looking like my only option at this point. Per the manufacturers website, the two are compatible. I'm just waiting for a reply from their tech support. Next will be a phone call....
83 Crossfire TA
09-08-2015 12:06 PM
