Grinding noise from under the hood
Car: 1991 Z28 camaro
When its either sitting in park just running or when slowing down theres a grinding noise coming from under the hood from the left side if you were sitting in the car and looking out. Is this anything major? any1 had this happen?
Car: 1986 Camaro T-Top
Engine: 2.8L V6 (MPFI)
Transmission: 5 Speed
Re: Grinding noise from under the hood
Check your power steering fluid level, seems to be the main cause from my experience.
1 Post
Car: 92 Z-28
Transmission: THM700R4
If it does it while sitting in park, get out and open the hood and try to hear where it is coming from. If you do not have an automotive stethoscope, a section of simple garden hose will do although you must be very careful with this while the engine is running. Try to listen to all the noises by putting the end of the hose on the various parts near the noise. I once had a similiar thing happen on my '02 Silverado and I thought it was the waterpump, with the hose I was able to correctly diagnose it as a tensioner pulley. Cost about $25.00. Try it and let me know.
If you're talking about the water pump pulley, it should be directly over the crankshaft pulley.
Car: 89 RS
Engine: 2.8
I had a grinding sound on a Cavalier and it turned out to be the alternator. I have a long screwdriver that I put on the part and I put my ear to the handle. Hope this helps.
Also it seems to go away as i rev it up(dont think the exhaust is loud enough to block it out so i dont hear it)...dunno if this changes any of the things u mentioned
Ok I took your advice hot92rs and used a chunk of garden hose and i have found where the noise is coming from directly (almost 100% positive) in the pic here i circled the 1 that is making the noise
http://img199.imageshack.us/img199/7282/pullypic.jpg
Power steering pump, the PSF tank is a dead giveaway. Did you check the fluid levels? If it's full, then the bearing is probably going out and you're better off replacing the entire unit.
1 Post
Car: 92 Z-28
Just because the pump is full of fluid does not mean that the pump is not bad. If it is making a loud whiney noise, it is the pump and you need to replace it. I have had the same problem before. Click on my forum name Hot92RS and look under one of my posts a little over a year ago, it is on page 3 of my previous posts 3-26-08 and this will give you all the info you need to replace your power steering pump. Congrats on properly diagnosing your problem.
1 Post
Car: 92 Z-28
Here is the link - https://www.thirdgen.org/forums/tech...ring-pump.html
ok so it went into the shop and its not the powersteering thing it was the ac compressor they replaced it but the noise is still there its just not near as bad as it was...any1 had this
1 Post
Car: 92 Z-28
If your shop diagnosed that the A/C compressor was the problem and you spent money based on their professional opinion and recommendation, you should take it back to the shop and discuss w/ them why, after following their recommendation, the noise did not go away. It would not seem unreasonable that other items besides the compressor were having mechanical problems as the car is older. Maybe you already have, what did they say to you? At least, they owe you a more comprehensive diagnosis. You should not pay for that. My suggestion is, take it back to the shop, have them look at it again, tell you what is additionally wrong, then make the decision to either fix it yourself or let them fix it.
kk...no i have not disgussed it with them yet...but the noise is nowhere near as bad as it used to b b4 i would slow down and it would roar now when im in park its there but not as bad
1 Post
Car: 92 Z-28
I would still recommend you take it to them to find out what additionally is wrong w/ your car. Were you having problems w/ the a/c not working? Even though they did not fix it completely does not mean they are not doing a good job for you. If you want to learn more about your car and maybe repair it yourself, take advantage of those people around you, such as the shop (who knows more about your car than we do because they have just worked on it), to learn more about your car. Go back to them, let them do an addtl diagnosis (does not cost any $), then make a decision as to what you want to do or present their diagnosis to us and we will help you to make a decision.
um naw there were no problems with it b4 other than that noise when i had the A/c on...i also called them today the lady was not in when i called..they were suppose to call bak but if they dont by tommorow the 26th by noon im gonna call them bak again
Btw forgot to ask..but does any1 know if this is SERIOUS...could this wreck my car(well more or less cause more dmg) if i leave the ac off?
Well i called em bak today and i got another appointment for it monday so by monday night tuesday latest i should know more
So from what I read, you had a noise that was there when the A/C was on. After they replaced the A/C compressor, it was still there, but not nearly as bad as it was. So you may have had a couple of problems. The techs that fixed your car may not have done a great job at diagnosing your issue. As with most techs, they hear a noise from one component and will replace it, there may have been a 2nd smaller issue that was also causing a noise. Not trying to back them up, but Ive seen it in the shop before, especially with older cars, like ours.
Well Hot92RS im not a tech nor do i claim to be... all i did is took ur advice and moved the hose around till i heard the noise...the noise came from there...no reason to be a ***...if i knew all the awnsers i wouldnt have asked the question in the first place
1 Post
Car: 92 Z-28
Chill out bro! Remain calm. Just wondering why we have not heard anything at all about the PS pump even though you said it was a major noise. Did your shop hear the noise at all? We have all been where you are w/ our cars. If we all are taking the time to post possible solutions, give us the feedback.
takes deep breath and exhales.../calms down...Um i dont know what happened with the PS pump i told them thats where i heard the noise coming from with a piece of hose when i took it in...and when they called me back they said that it wasnt the PS pump and it was the A/c compressor...and i was like ok not gonna argue cause they pry know more than me so didnt really say anything(also was buzy at work and getting *** chewed so)...but i would have to assume that they did hear it but then again assuming makes a *** out of you and me so. but they were suppose to look at it today didnt hear anything from them so ill pry give them a call bak tommorow to see what they found out
1 Post
Car: 92 Z-28
If it is the ps pump, follow the above mentioned thread and hopefully that will take care of it.
so they called me bak today...and they said it is the PS pump which i find funny when they told me it wasnt in the first place..but oh well and there just gonna replace it cause atm i dont have the time
1 Post
Car: 92 Z-28
I have done that also when I did not have the time and I needed the car for a dd. At least you know you were correct.
Today i got a phone call from them saying that im missing the brackets or something for the PS pump(and they told me it would b ready today)so i have another week to wait..btw would the brackets them self missing be able to cause the noise?
also ty for being able to help me find the problem
1 Post
Car: 92 Z-28
If the pulley is not aligned because of missing parts, it could be. I will check later what pieces could be missing.
