cold air intake - worth it?
Car: 1991 Firebird
Engine: 3.1L MPFI V6
http://cgi.ebay.com/ebaymotors/PONTI...Q5fAccessories
Is this intake worth it for my bird? It comes out to $54 shipped. Will I see any noticeable performance gains? Is this really any better than putting a K&N filter in my stock intake?
Thanks!
Thanks!
1 Post
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
Re: cold air intake - worth it?
not worth, it, you could probably make it for cheaper and you won't see a big difference because it sucks from the stock location.
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
No, not worth it. They don't have a spot for the MAF sensor.. I bought a universal intake kit and just drilled a hole for the air temp sensor. It sits lower in the side fender so cold air does get to it, but it didn't make enough of a difference to justify all the work lol. slightly better throttle response.. slight..
Car: 1986 Camaro T-Top
Engine: 2.8L V6 (MPFI)
Transmission: 5 Speed
I tried a K&N and it wasn't worth the cost, I actually got better performance just using a new WIX filter and the oil also seemed a lot cleaner on the last change as a result. I am guessing the higher flow is at the cost of less filtration.
Car: Many
Engine: Several
Transmission: Automatics
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
If possible you are better off getting a Dual Snorkel Air Intake w/the Air Filter box. Something like this.
Cut the bottom of the Air Filter box to allow more air in.
Car: Many
Engine: Several
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
that intake on ebay is not even a cold air intake, its a low restrictive hot air intake. If your going to do something like that your going to need a way to get fresh air from outside in, or most people drill a hole on the passenger side where the battery was and duct it through there.
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Nope, Firebirds have to low a hood to fit that under there.
In my opinion, the stock location od the intake isn't bad. It's well out of the way of the radiator and the air there is just about outside temp. The thing on ebay is a rip off, just shiny tubes and a cheap filter. If you want to have a good intake build this one:
http://thirdgenmods.firebirdv6.com/coldair.html
Engine: 2.8 - LS1
I placed my filter in the fender and directed some ducting to force air to it. So as many of TGO guys deny it, mine IS a cold air intake.
Besides, if you find the right parts it doesn't cost much.
just that ebay kit is way overpriced. Then again i kinda took parts from my accord to fit it...
1992 Trans Am
05-10-2023 07:19 PM
Brinkkl2000
08-04-2018 08:29 AM
