its up for grabs
its up for grabs
http://videos.streetfire.net/video/8...ale_682285.htm
moved to ny
hate to get rid of it but i got a kick *** job up here and im saving for a new camaro,wont have the room to have 2 toys
moved to ny
![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
Re: its up for grabs
as long as there is a way to tune the v6 motors ill deff be getting an LT and it wont be long before i drop a turbo on it
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
where abouts in new york are you located now. Id love to check out your car. I look at all your posts just WISHING i could do this to my car. Im not very good at fab work nor do i have the tools and equipment to do a turbo set up. Either way id love to see it once in person before someone gets there hands on it and rips it apart or something.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Many
Engine: Several
Transmission: Automatics
also 4.3's are popular. neither are as cheap to build as the small block, but im sure you already know that.
its a beautiful car, good luck with the new one, i like the third gen more than the new ones.
we already know these v6's can handle the power,its more my concern over what can be done with the direct injection system as far as tuneabiltiy
Engine: 3.1L, 4.7L
ya i know where that is....that would be a road trip for me tho...new york is a pretty big state. Well good luck on everything man. Your car has been a huge inspiration to me. Id love to boost my v6 but will most likely end up just dropping a 350 or 383 in with no computer, emissions or anything and just call it a day. The new camaros are nice. My buddy just sent me a text the other day cause his dad bought a new 2010 Camaro LT. Its yellow which idk if im so crazy about but its FAST for a six(so ive been told). I might go out and take a look at it this weekend if the weather holds out. If you boost one of those that would just be crazy. You will have to get rid of alot of stuff tho. The engine bays are just jam packed.
Minor surface rust on passenger side rear quater panel,
needs new paint maco job on it now and its fadded and thin in spots
MOTOR
1992 3.1 v6
std bore
brand new kb pistions (8.5-1 cr)
plasmamoly rings
king engine bearings
arp rod bolts
factory crank and rods
(roatatiang assembly lightened and balanced to turn hi rpm)
hi volume hi preasure oil pump (60 psi idle 110 psi redline)
custom grind delta camshaft 268/272 hyd flat
new lifters (modified for high rpm )
comp cams pushrods
comp cams springs locks and retainers
springs are 125# seat 340# open
massivley ported heads
ported intake 3 piece unit + one sheetmetal upper plenum
turbo kit.
321 & 316L stainless headers 1.5 inch primarys .065 wall. 3 inch to 2.5 inch reducer collectors
2.5 inch crossover
stainless flanges
garrett/fullrace 60-1 turbo t3 .8x/ .70 cold side
turbo xs hp-mbc
ebay wastegate 38mm and ebay bov
2.5 inch from turbo to fmic
3.0 from fmic to tb
3.0 inch downpipe out to factory cat location
driveline
tci super streetfighter 700r4
tci ssf 9 inch converter restalled to 4500 rpms
4:10 7 5/8'th rear gm gears
welded diff
c-clip elimns ( not installed)
ds loop
suspension
3 way adj ce engineering drag shocks
1le springs in rear
1le sway bars fr/rr
wonder bar
lcarbs
bilstien front struts
morroso drag springs up front
misc stuff
nos brand wet nitrous system setup as dual nozzle 100 shot never used it
42# injectors
megasquirt 1 v2.2 standalone ( setup for fual and ign with antilag, knock detection, and nitrous control)
dual walboro 255 lph pumps
custom boost refrenced fpr
2 rear 15x8 weld draglights w 28x10 slicks mounted
1 spare block
1 spare set of rods and pistions
1 spare crank ( short stroke 2.8L)
+ more spare parts and other parts i can think of atm
car dynoed 268 whp and 370 ftlbs on a mustang dyno with only 9 psi and 8* total ignition timming
car cuts 1.8 60's on 245/55/r16 street tires and 1.7- on the slicks launching at 2-3 psi of boost
car is a solid 12.50 car on low boost 9-10 psi once dialed in
should run low mid to low 11's on high boost
avg 32mpg highway,deff makes a nice lil sleeper
6k neg
MOTOR
1992 3.1 v6
std bore
plasmamoly rings
arp rod bolts
comp cams pushrods
turbo kit.
2.5 inch crossover
stainless flanges
turbo xs hp-mbc
3.0 from fmic to tb
driveline
welded diff
ds loop
suspension
1le springs in rear
1le sway bars fr/rr
wonder bar
lcarbs
misc stuff
42# injectors
1 spare block
6k neg
Car: 83 firebird/camaro conversion
Engine: carbed 350 very mild build
Transmission: th350
Axle/Gears: 3.42 posi
you didnt post how much??? or is that against the rules
thnx man its nice up here, im about 45 mins from lebanon valley.
ill be back down in jersey next weekend if the cars not sold its comming to ny with me and ill keep it.
but a lt camaro is def fin the near future,got a nice job up here started at 17.50 an hour woooot
Car: 1992 Camaro RS
Engine: Ls1
Axle/Gears: 4th gen 3:43
Congrats!!!
Thank you for posting about your engine, I plan on doing a similar build. What type of piston style was it? Domed, Flat, etc. ? If the crank and rods were also forged would it be able to take higher boost?
Again congrats on the new job
the pistions are dished,no need to upgrade the crank or rods, arp main studs and arp rodbolts are all u will need, u will break the block before u need to worrry about rods and crank
Mongoose462ci
09-16-2015 11:46 PM
