92 RS, SPITS, SPUDERS, STALS
Car: 86 Z28
Engine: 383 4bolt main,8504barel p&p heads
Transmission: 700R4,1800stall,shift kit,etc.
Axle/Gears: chevy posie 10 bolt
My buddy has a 92 RS long story short stumbles on acc. idle stals, pops in the intake. Replaced cap, rotor,plugs, wires, did the unplug sensors, see what happens. The only thing that didn't change anything was the IAC valve. I'm pretty sure it's the IAC it's on top of the throtle body. ANY SUGESSTIONS FELLOWS?
Car: Many
Engine: Several
Transmission: Automatics
Re: 92 RS, SPITS, SPUDERS, STALS
codes?
maybe firing order is wrong. may be an issue. make sure the dist. is tight.
1 Post
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
possibly timing being off. can really make your car run like crap.
Car: 86 Z28
Timing is all good check it with light, dist. is tight there are codes but dont have obd1 tool any thoughts?
Car: 86 Z28
Car: Many
Engine: Several
http://www.troublecodes.net/GM/
was the wire unplugged when you checked the timing?
Car: 86 Z28
what wire? I have V8 carb, no ecm. so no ses light. not sure how to check it????
Car: Many
Engine: Several
get a timing light clip the power lines to the batt. spark plug end to the #1 plug wire as close to the end as you can. find the pointer, should be above the crank pulley, disconnect the white/brown wire along side the passenger fender. start the engine and point the light at the pointer. watch for the mark to line up witht the pointer.
Car: 86 Z28
i'll try that next is there anything u can do to read the check engine light codes it is on I know u have to ground the term. but how? and does the dash lights blinck the codes or what?
Car: Many
Engine: Several
Car: 86 Z28
thanx
Car: Many
Engine: Several
