Pacesetter Mid Tube Headers???
Car: '90 Camaro RS, '94 Miata, '95 F-250
Engine: 5.7 TBI V8, 1.8 PFI L4, 7.5 PFI V8
Transmission: 4L60-OD, 5spd Std, 5Spd Std
Axle/Gears: 2.73 Posi, 4.10 LSD, 3.55 Posi
I'm looking at a set of mid tube headers for my girlfreinds '87 Camaro, it has a 2.8L V6 and 700R4 transmission. They're the Pacesetter mid tube headers offered by JC Whitney (ZX311104) they have 1-1/2" tubing and 2-1/4" collectors. are they worth the money? I'm not looking for a major performance boost for this car, but will it give it a little more kick? The Camaro has stock pipes and cat with a Flowmaster 50 series single in single out muffler
--also--
What would these same headers do on a '86 Trans AM with a 3.4l/T-5 W/C swapped in it? The engine currently has a .427/.454 lift roller cam, 305TPI injectors, Pro-Form roller rockers, Cold Air intake, Accel coil, module and wires, AC Delco plugs, .040 flat top pistons and .020 over valves. I have a two disc clutch and pro-billet shifter and 3.73 posi rear, the exhaust is the stock mani's into 2-1/4" stainless piping through a Random Technologies cat and a single in dual out Flowmaster 50 series muffler with 3-1/2" tips
--also--
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: Pacesetter Mid Tube Headers???
It would be a good upgrade over the stock anchors.
I know on the Fiero 2.8 the exhaust manifolds were a huge restriction but not as big as the intake but you could free up 20+ hp from headers and a y pipe.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
But, then, there is the whole issue of the Accel ignition... Should've gone with an MSD system if you were going to put that much money in it.
92projectcamaro
01-18-2016 08:00 AM
