timing on a 2.8 need some info
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
on the timing on a 2.8 i know it is 10 deg before tdc on compression stroke...and i know fire order is 123456....my question is will the car still idle if it is 180 deg off..other words on opp stroke because you will have 2 tdc won't you.compression and exuast
Engine: 350 crate
Re: timing on a 2.8 need some info
i have a 2.6 v6 and i'm wondering on the compression stroke and the exaust stroke..it is 10 before tdc right now..but my prob is will it still idle if it is backwards..if it is on exaust stroke.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You won't get the engine started if it's 180 off... the engine will be too busy backfiring to run properly.
Engine: 350 crate
ok i got my timing set i was 13.6 off..it still sputters and backfires..i was lookin in the hayes manual and it said something about it might be a stuck valve..how would i check this and fix it with out pulling the heads..
Engine: 350 crate
i did undo that little wire for the timing..i got the car running now it just backfires when i romp on it.could it be a stuck valve....got it up to 60 today also ..in a 200 yrd strech on my road..and it will white smoke the one tire i need a posi in it ...just backfires when getting on it..
Engine: 350 crate
Engine: 350 crate
close this thread
