Fuel Pressure Regulator...how many of you have replaced this?
Old 02-16-2009 | 01:47 PM
Twitch RS's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
Transmission: 700 R4
Just curious how many of you have needed to replace your fuel pressure regulator? and what was your car doing before you replaced?
Old 02-16-2009 | 01:59 PM
Q's 91z28's Avatar
Car: 91 Z28
Transmission: Automatic
Re: Fuel Pressure Regulator...how many of you have replaced this?
I just replaced mine on Saturday. My car was boging down on me, though it was the regulator but still seems to be doing it. FYI You'll need some tamper proof torque bits to complete the job
Old 02-19-2009 | 01:00 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Had it off a few times. I don't remember why I had it off the first time when I was doing the 3.4 swap.
Second time I was losing fuel pressure fast. Finally found if I pinched the return line closed, it held pressure. I replaced the regulator and it still leaked. Had to actually replace the fuel rail itself.
Old 02-23-2009 | 12:43 PM
Twitch RS's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
ya I still havent been able to do it cause its been too cold
Old 02-23-2009 | 08:35 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
I'm about to replace mine in the coming week. I'm having fuel problems, and changing my fuel filter tomorrow, then if that doesn't fix it, I'm doing the whole fuel rail system. Manual says in the 2.8/3.1 the fuel pressure regulator and fuel rail has to be replaced in whole or the FPR will be damaged or something to that extent, I'll edit this post once I read the manual again. I'll let you all know how mine works afterwords!
Old 02-24-2009 | 01:15 AM
Engine: 3.4
[QUOTE=d00012;4055890] Manual says in the 2.8/3.1 the fuel pressure regulator and fuel rail has to be replaced in whole or the FPR will be damaged or something to that extent,QUOTE]
BAAA!! They just want you to spend $300 on a new rail instead of $15 (or whatever it was) on just the pressure regulator. The rubber diaphram is kinda delicate. Just do it carefully and you'll be good.
Old 02-24-2009 | 10:12 PM
Twitch RS's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
pretty odd...today I went out and fired it up and it idled at 4500 and slowly crept to redline so i shut it off restart and it sits at 4500 restart a couple times and still there then i go up and unplug the tps and it lowers to 3500 then plugged it in and down to 2200 and then I had to leave...im confused
92camaroJoe
07-29-2023 07:57 PM
specialized
06-18-2022 09:26 AM
wayshegoes
08-17-2015 12:00 PM
92camaroJoe
08-13-2015 06:07 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: Fuel Pressure Regulator...how many of you have replaced this?
