diagnostic scanner for 90 camaro
Looking for some help with choosing a diagnostic scanner for OBDI and ODBII. I have searched online and cannot find if real time values are available for ODBI scanners. I am in the process of troubleshooting a 3.1 MPFI no start, and my 99 Taurus check engine light came on. Can anyone recommend a "cheap" diagnostic scanner? Most of the threads that relate to this subject are 3-4 years old. Thanks....
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: diagnostic scanner for 90 camaro
If you are looking to pull your error codes(check engine light on), read this link... LINK
No need to buy a scanner when a paperclip works just as good.
Thanks, I have been using the paper clip for 18 years.
I have decided to keep this car for as long as I can. I was hoping to get a scanner that would display the TPS voltage, O2 sensor, cooling temp and stuff like. If this cannot be obtained by a scanner for a 90, let me know
Car: 91 Camaro
Oh ok I see. You might want to check out moates.net. They have a lot of ECM burning/data logging stuff.
