rough idle/vibrate during acceleration
Hello all. I just purchased a 1992 camaro RS 3.1L v6 about a week or two ago. It ran great up until this morning. When coming to a stop the idles are real rough, and when accelerating the whole car vibrates pretty badly. Its not accelerating as fast as it use to, especially from a stop. Any help would be appreciated!
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Re: rough idle/vibrate during acceleration
Could be a variety of problems causing this. Have you scanned the computer for codes? Without that your playing a guessing game and throwing parts at it can get expensive.
O`Reillys or Advance auto will scan your computer for free if you dont have your own scanner.
Theres no check engine light on, but I have an advance auto near by. Should I run over there to get it scanned?
EDIT: Ran up there to scan it. They broke all my clips on the bottom of my dash to get to the plug to scan it, then told me the cars too old to scan. They told me to start with plugs/wires/distributor.
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
thay need to use an odb 1 scanner or do a serch here on pulling the codes all you should need is a paperclip thats how it is on my firebird
try here its in the FAQ tab
https://www.thirdgen.org/service-eng...ht-error-codes
it should help ya out
Problem figured out. Me and my moms boyfriend took a close look and found out that the spark plug wires were touching the manifold. It fried all of them. They are replaced and the car is 100% again. Thanks for your help though guys!
Car: 89 Firebird
Engine: 408
Broke all the tabs on your dash? I cant even picture how they could have done that. Glad to hear you got it fixed but sorry to hear they messed up part of your car. Unfortunatly not all auto parts stores employ the brightest of people.
Pac J
05-17-2020 10:44 AM
RedLeader289
05-28-2019 01:47 PM
