just how much compression can an Iron head take
I have a 2.8 camaro that I use for autocross racing. Since I am running against V8 cars I would like a bit more power. I'm wondering how much compression the Iron head engine can handle? The class I'm in I can change anything but the throttle body. I was hoping for an 11:1 comp 3.4 liter and about 200 Hp at 6500 RPM but realistically I know I'll never see that due to the restrictive heads but what is the limit for an iron head v6 N/A?
Re: just how much compression can an Iron head take
u can run 12.0 or more depend son how u tune it and what u use for fuel
gm used to sell a high compression piston for the 2.8 that i think was a 11.5 or 12.0 cr piston
so if and I do mean if I can find a set of these UBER rare GM pistons and match a cam to them with ported and polished heads, I could see ??hp at say 6500rpm??
Oh and can the 2.8 pistons be used in the 3.1 or did they not change the rod length?
1 Post
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
the pistons will fit, its the same bore. its just about finding them and possibly getting them to work without blowing something up.
OK so the 3.1 used the same rods as the 2.8 and changed the pin height
oh well I'll start looking for the UBER rare GM 11-12:1 comp pistons
If I can't find these pistons what other ways can I raise the compression. I imagine the heads could be shaved but then there's intake issues and it goes on and on.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you can only shave teh heads so much before you have to start shaving the intake to keep teh angles between them good. run a thinner head gasket, or if you're feeling really balsy, no head gasket, & o-ring the bytch!!!!! (rings on teh block, so if you need to shave the heads again, the groves won't be affected. (experiment on an s-10, jeep, or isuzu engine )
maybe even put the csi on a manual switch
isnt there a ford piston that fits the 2.8 to bring up the compression?
Engine: 5.7 / 7.4
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Do I really need to bring up what Ilja_hamburg did again? 2.8 pistons can be made to work with a 3.1 crank by milling the pistons (don't remember how much). Gives you 10.4/1 cr with 0 deck height. But again it depends on what fuel & cam you're using.
ambainb
04-25-2016 09:21 PM
gixxer92
09-01-2015 04:32 PM
