Ditching my stock smog pump HELP
I have an 89 Firebird 2.8, I'm in the process of installing Pace Setter headers, a high flow cat, and Borla cat back exhaust. The Pace Setters have no hook up for the stock smog pump setup. Thats good cuz I don't want it anyway, but my question is seeing how the smog pump is ECU controlled, will it matter if I just remove it all together and plug all vaccuum lines, will that trigger any check engine lights or will everything be fine. I'd appreciate any help I can get on this
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Ditching my stock smog pump HELP
You'll be fine. Search this forum for 'remove smog pump, 'smog pump delete' or other variations. Lots of information. I removed mine and ran a shorter belt with no problems.
theshackle
03-05-2017 06:37 PM
transaero
08-31-2015 01:14 AM
