Got a code 32
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
Got a code 32
I got a code 32 yesterday and I've been googling every since. Is there anything I can try b4 I spend nearly 300 for a new egr? My 3.1 only has 96,000 on it.
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Got a code 32
clean up the passages and check for proper operation of the egr first. blocked egr passages can cause those problems
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Got a code 32
You should be able to test the egr operation by idling the ingine and physically pushing up on the bottom of the EGR diaphram. It should almost stall the engine.
Car: 1992 Camaro RS
Engine: 3.1L
Axle/Gears: open 3.23
Re: Got a code 32
He can't use that method ToeBird. He has a 92 and all 3.1l's 90-92 used a Digital EGR Valve.
OhioTemplar, you should look in my old thread "92 3.1 EGR Problems @ 9 mpg Code 32".
Look at the Pics, and clean everything, including the reburner line that goes from the side of the manifold and right under the EGR, to the side of the throttle body.
Also, don't try to block it off as I did. Being digital, the computer will always look for it, and you won't gain any benefeit. (sp?)
BTW: The search function works pretty good... *hint**hint*
Re: Got a code 32
Aww lame. Sorry for the misinformation... I've never had a 3.1 or seen the digital valve. Good luck though!
Engine: 3.1 V6 MFI
Re: Got a code 32
Ok, I went through that whole thread.
QUESTIONS: will I get a check engine light during highway driving if I block off the egr?
And also, 92RS3.1 - Do you think I could buy a block-off plate from you? I don't have anything to make one.
Right now I'm getting 230 Miles per tank (running it till it dies) - But last year b4 I got the code I was getting 28 MPG on plus gas. What kind of highway fuel economy can I expect from this based on my excellent fuel economy b4 the egr failure? The same as I was getting b4? Less?
Engine: 3.1 V6 MFI
Car: 1992 Camaro RS
Engine: 3.1L
Re: Got a code 32
Confucius101: To clean the carbon buildup, I have used lots of Carb Cleaner.
OhioTemplar: It depends. Could you get a pic of your EGR Valve for me. I'm just wanting to make sure which one it is. Vacuum or Digital?
I have access to 89t-top_maro's car. I can make a plate for both of them. So if you need one just tell me which type it is. I'll prolly PM you soon about mailing it to you.
btw, if it is vacuum operated, you will only lose 1-2mpg.
Engine: 3.1 V6 MFI
Re: Got a code 32
What kind of highway mileage do you think I'll get blocking off my digital egr? I'm about to do some ford or accel injectors, so it'll probably get bumped back up from the nozzle design of those anyway.
