3.1 Injectors
Car: 84 Firebird / 91 Camaro
Engine: 2.8 / 3.1
3.1 Injectors
What should the ohm resistance of a injector be i am wanting to test them but not sure what to look for.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 3.1 Injectors
Most fuel injectors should be around the 12 ohm range, with no more than a full ohm between the lowest and highest readings. You can check a full side at a time, and this way, you should read 4 ohms on your multimeter.
