What do these numbers mean?
YrModelTransEngine
code/typeCRDispl.HPTorqueInduc-
tionManual
std.Manual
opt.
(G92)Auto
std.Auto
opt.
(G92)87Sport Coupe
LT
RS*
FirebirdM5,A4LB8 V68.9:12.8 (173)135@4900160@3900MFI3.42----3.42 ----
more specificly is this what is tha auto std. 3.42? what does it mean what is it, is it good?
tionManual
std.Manual
opt.
(G92)Auto
std.Auto
opt.
(G92)87Sport Coupe
LT
RS*
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: What do these numbers mean?
It looks like a mess to me...
Best I can tell, it says 135 hp 2.8 V6 with multiport fuel injection and 3.42 rear.
Good is a relative term; I like 3.42s, others don't.
i dont know its so much work. i got in to the engine today, i gotta drop the rear to take the trans out...not cool. lots of work on my rust bucket...but ill get it someday
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Why do you have to drop the rear to get the tranny out? Also what are you doing to your car? Rebuild? Rust repair?
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
yup they came standard with 3.42s until '90 when they went to 3.23s in the Auto and 3.42s in the T-5s, I my happy with my 3.42s but a posi unit would be nice
im pulling the engine and trans out to swap a V8. got to unbolt the torque arm, and the book says to take out the rear end springs, unbolt the cross members, and loosen the torque arm in order to pull the engine and trans, so that the arm doesn't twist the axle. but the under body is rusted, and the fuel lines are rusted . so i was going to take it off anyways.
I'm going to take the engine out
the rear end off, the front suspension off, flip the car over and por 15 the whole under side, then start to rebuild with new/refurbished parts. if this car dident have sintemental value id buy one in better shape.
Car: 90 IROC Z
Engine: 350 60 over
Transmission: t5 and 700r4
Axle/Gears: 3.08
If you jack the body you can take the bolts out and the tourqe arm axle no problem.
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
last time i pulled the tourqe arm out i swtiched positions on the bolts so the heads are on the top and the bolts pull from the bottom ... soo much easyer for fast removal..
LT1Formula
10-08-2015 08:34 PM
3.8TransAM
09-27-2015 08:37 PM
