Should I convert my 3.1 over to MAF?
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
So I put on a snorkel from an 89 camaro and it's got the MAF sensor on it. I was going to go out and cut a piece of pipe to fit in it's place tomorrow and sell the MAF on ebay. But then... I read in a couple threads that the MAF config is better than speed density. Is this true? If it is, is there a way I can just pop in a computer from a 2.8 and install the plug and wires to the MAF? Has anyone on here done this?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Should I convert my 3.1 over to MAF?
The wiring is quite different. Its not as simple as "plug n play".
You would have to either cut and redo the ends. Or get new plugs and repin that.
Honestly, alot of people swap to SD. But then I guess some swap back to maf :shrugs:
In the OBD2 form that I am learning on mine. The SD is best for down low and partly reads the maf. Then MAF only for higher up(4k n up in OBD2).
So I say install a system that is best used for the rpm/style driving you do. For me, I hardly get above 4k, so the SD is best in my use.
Engine: 3.1 V6 MFI
thanks for the info. I'll just stick with the SD then. I don't do much fast driving. or WOT for that matter.
BumpaD82
02-26-2016 02:57 PM
MikkoV
09-09-2015 04:25 PM
