Pre Oil question
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
Pre Oil question
I am trying to pre oil my motor after a rebuild. My question is if the pushrods are not adjusted just right will it not pre oil or does that matter about the oiling?
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Pre Oil question
They probably should at least be tight I imagine so the oil can travel to and through them.
Axle/Gears: stock
I have adjusted them like what the haynes book says. Going to get someone to look at them and make sure befor i firy the motor up. But i cant get the oil to come out of all the pushrods just a few of them. I have tryed to trun the motor over and them try to oil but still just a few of them will oil. not sure what to do now
No, they don't need to be tight, just snug.
You will need to turn the engine over (socket and ratchet on the crank serves this purpose well), to open up the oil passages to all the lifters. the oil passes through the lifters and then to the pushrods, to feed the rockers and spray on the valve springs and guides.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
you did make sure the inside of the pushrods were cleaned while eng. was apart . if not they can plug up with sludge , blocking oil flow .
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
when u adjusted the pushrods did u set to 0 lash means snug not tight so its not pushing the pushrod into the lifter and also rotate the engine as adjusting each cylender.. also did u fill the lifters with oil before u installed them?
Axle/Gears: stock
I blew the pushrods out and made sure nothing was in them. I think i got the lifters full of oil. i poured oil on them when i put them in. I adjusted the rockers the way the hanynes manule said to. Adjust half of them one way and rotae engnice and do the other half.
Navy8125
08-21-2015 09:32 AM
