Man Down...Time for new car.
#303
Car: '86 SC
Engine: 2.8
Re: Man Down...Time for new car.
have you had any luck with the tranny, i know that was a while ago but i want to throw this in anyway, i have a friend who had to ship a large item across the country ( TN to CA) and Ups was gonna charge him $250 for shipping, so he just went out and bought it a Greyhound Bus ticket it took about 10 days to get there but he saved $200
#304
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Ive decided to stick the tranny that I have back in. It ran very well before I took everything out...so I figured it will work.
Now if, between now and when I'm ready to put everything back in, I find enough spare cash Ill probably get one. But I'm not really concerned about that...I'm more worrying about getting the engine runnable and getting my car back with the repairs done.
#305
Car: 91 Camaro
A little update...Not much to report but Ive been putzing around a little here and there. My hours at my job have once again been cut WAY back, so I haven't had the money to buy certain things that I still need. I got the injectors all wired up to work with the old wire harness...
I also got the TB spacer all situated...
Still waiting on a crank pulley and some fittings...once I get those I can get the timing wheel, spacers, and oil pan on.
Other that that Ive got 2 holes in the UIM, and 1 in the LIM to tap and plug...a couple misc wires to lengthen, hook up some new sensors, and get my fuel system bought and installed.
I cant wait till I get my car back ( ) and I can have some REAL updates.
#306
Car: 91 Camaro
Well here we go again. It has been entirely, 100%, undoubtedly, and painfully to long since I had my car in my possession. But......
......She got her first bath at home again. The paints not perfect...but it will work for me...I just want to drive the damn thing!!!
There are still things that need to be done. They didnt bolt up the GFX on the driver side...and they lost the nuts for the front of that GFX...My exhaust tips are now a teal color ...and the bolts in the frame are still in there
But at least I have it back and I can get it done. All that I still need to get/do before I can drop the engine in is get those bolts out and deal with the transmission.
#307
Car: 1987 Pontiac Firebird
Engine: 2.8
Transmission: t5
Axle/Gears: not low enough
that is BS I hate when a shop does someone like that and hes your "friend"? other wise great thread and dont get to frustrated these things take time be cool and the results will speak for your patience
#308
#309
Im about at wits end with these freaking bolts. Ive used all different types of drill bits/extractors and still nothing. Im about ready to have it towed and have someone else deal with this. I dont have the time or resources to keep buying drill bits to have them not work
Who would have thought 2 bolts could be so stubborn?
Anyways, Nice to say someone else restoring a camaro to its former glory, and working with what they have. I'm rebuilding my 2.8 to a hybrid as well....in fact could use some advice or possibly even help, whereabouts near pgh are you? I live in Coraopolis/moon twp.
#310
Car: 91 Camaro
Im up near the Cranberry/Zeli area. Although I dont really have time to make trips to Moon...sorry. My days off are pretty random and filled with stuff...sorry.
#311
Car: 91 Camaro
Ok, so its been a while since Ive updated anything on this project. Got a new job within the last 4 months, so a lot of my effort/time has gone into that....plus I had to deal with this...
My daily driver got totaled while I was on vacation in my home state of Minnesota...so yea that took up a lot of money/time and added a lot of stress/problems.
But long story short, picture time, here is where I am now...
Ive got to finish up the wiring, buy a few more sensors, and deal with a few more other minor stuff... But its coming along now.
#315
Car: 91 Camaro
Oh don't you worry...the only reason I'm waiting to put it on is to get the motor broken in. Seeing how this is my first build I want to make sure everything goes smoothly....that and I want to see what she makes on a dyno before the turbo...
#316
Car: 91 Camaro
Well, I havent had much time to work on this for a while due to some new hobbies of mine...which Im setting aside now so I can get this done. Im pushing for 11/6 to be the first start up.
Here it was at the beginning of the week...
Heres how she sits now...
I have to hook up my Y-pipe, cat, vac lines, and cooling system(still waiting to get my hoses from store I bought them from)...Other than that I should be good to go. So close now.
#317
Car: 91 Camaro
OK....so here's where I'm at now...
There is no power to anything. Battery was dead and wouldn't hold a charge anymore so I buy a new one....still nothing. No headlights, interior lights, brake lights.....nothing.
Everything I can see is hooked up correctly...I'm completely stumped...
#319
Car: 91 Camaro
Could it be a bad ECM? I know that I had to replace it before I started the rebuild.
#321
I'm thinking perhaps he doesn't have the battery grounded? Or maybe its loose? I would also check the wires going to the starter solenoid cause I believe if one of those is disconnected it can also kill the electric.
#322
Car: 91 Camaro
Ok so Im still trying to track down this electrical issue. Ive checked more places and I seem to have power everywhere in the engine bay...just not in the car. And as far as I can tell I don't have power to the fuse box under the steering wheel.
Quick question. What are these?? They are right off the little junction block behind the passenger headlights...
#323
Fusible links, basically they are inline fuses to prevent an overload.
#324
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
one of those fusable links provides power for the cooling fan. junction also for the alternator. i had to replace of of the links with a new inline fuse.
also check the wires at the starter. if all the wires are not hooked up right no power inside the car.(4 i think)
#325
Car: 91 Camaro
That's what I thought they were...just wasn't sure.
I'll have to check the starter when I get back from work. Didn't know a bad connection at the starter could kill all the power
#326
Car: 91 Camaro
Well I got the electricity problem fixed and guess what?
I have to part ways with the whole car. I cant keep it anymore. Money, space, among others have made it time to part ways. So close...yet so far.
There's a post in the Camaros for sale section.
