need help finding new crank
Car: 1984 Camaro Sport Coupe
Engine: 2.8 L v6 (Carbureted)
Transmission: Automatic
hello, i'm rebuilding my 1984 (small journal) 173 engine and I can't seem to find a new crankshaft for it. I've found remanufactured ones, but I've already got OEM bearings and I like the features of some of the new SCAT or Eagle ones, like being made out of steel or being nitride hardened. I don't want to spend much more than $250 though. Eagle makes a 173 std. steel cast crank, but i believe it's for the large mains type because it has the casting no. (817) and I believe mine is (504). I'm also having trouble finding new rods too. Could someone please direct me in the right direction?
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: need help finding new crank
Take a right turn and head to the nearest wrecking yard. While you're there pick up a complete (core engine) 1987 or newer 60 degree V6 from an f-car or s-truck. Bring home, start over.
Sorry man, but that's my advice. I've seen too many people go to a lot of trouble with your engine block and then repeat the process. There's a reason you can't reuse your crank and another (even better) reason that Eagle doesn't sell one for your block; liability. Your block doesn't oil enough for a stock application, let alone pounding on it.
Turn back before it's too late!!
I would agree however that a 1985.5 or newer block and crank should be used, as the small journal cranks were known to break, very few large journal cranks break even at some insane HP levels.
Engine: 2.8/TBI/TPI
It's not a myth. Not just the crank is vulnerable but the block itself. The oil passages are not the same as the newer blocks. They are not the same size or always in the same position (depending on the year.) The block is not tough enough to allow it to be align-bored to the larger size and using a smaller steel or turned down crank will most likely break the block at the main webs.
I am searching like mad on ebay and everywhere else for another copy of the GM V6 performance manual that I had from 1990. If I find it, I'll scan and post every page just to help out. I'm not trying to fire you up; I know what GM said in that manual and I know what I had to sell at the auto parts store.
They match.
They match.
They match.
They match.
I don't think anyone mentioned alignboring the block to accept the larger crank, I mentioned grabbing a 1985.5 or newr block, because it has the larger mains.
The only improvement in oiling is in the genIII blocks, all gen I and II blocks share the same cam priority oiling system.
well, I can't find a new 173 crank with cast# 504 except an OEM iron one directly from GM and they want like 500 bucks for it lol. So I guess I'll get the remanufactured one, it comes with it's own bearings to fit, and I guess I sell my extra bearings on ebay, still having trouble finding rods too, I've already spent a bunch of money on this engine and I don't have the resources to convert my car from carburated to MPFI, whether it be knowledge or tools. Any help find some new rods and crank for this engine would be greatly appreciated though.
BTW, I'm not planning on increasing horsepower much on this car, my "small journal" crank is in remarkably good condition after this rod bearing failure and I'll probably keep it as a spare, the metal hasn't blued at all that I can see. The only outstanding things I noticed when disassembling my engine was a clogged EGR port and a dirty/maybe slightly clogged lifter and of course the spun bearing. I believe my block is strong enough to last just as long as any later year block and handle any of the driving I do with it.
hey guys, don't laugh but how do you find out all the measurements for my rods like rod length and journal diameter, because i'm just completely clueless how to find out what kind of rods I need
ok, thanks, I just wanted to know though, but I called ARI and they said they didn't have the small mains crank and that they can't get them anymore cause they keep breaking so I've found a remanufactured one from RockAuto that I'm going to get, I guess there are no third party manufacturers of my crankshaft because of liability/popularity issues so I'm gonna have to do with a remanufactured one.
I've got another question, I've found a set of headers from pacesetter. In the description is says it will retain pollution control systems, does that mean it will accept my stock A.I.R. system? Also, will I be able to keep my air conditioner. The reason why I as is because I'm having trouble finding the passenger side exhaust manifold and I need new ones for both sides. I figured I should just switch to headers while I'm at it and they're made of steel, not highly corrosive cast iron
ambainb
04-25-2016 09:21 PM
Street Lethal
08-12-2015 11:33 AM
