Car idles at 1500 rpm?
Car: 1987 Camaro RS
Engine: v6
Transmission: 5-Speed
my 87 rs will sometimes idle at 1500 rpm. sometimes it will drop back down to 1000 and lower after a rev the engine once, or it will drop, but takes a while to get there. Just wondering what could be causing it to idle at 1500.
Re: Car idles at 1500 rpm?
Originally Posted by yourtoyslive
my 87 rs will sometimes idle at 1500 rpm. sometimes it will drop back down to 1000 and lower after a rev the engine once, or it will drop, but takes a while to get there....
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Either replace it or try to clean it. It is located in the throttle body. It has a 4 wire connector going into it and it screws into the throttle body. It is a cylindrical shaped motor.
Here is a pic.
http://www.autozone.com/R,APP462901/...ductDetail.htm
Here is a pic.
