Knock Sensor
Car: 85 Firebird
Engine: 2.8L
Knock Sensor
Hi guys, I finally got data logging working, and am seeing a constant error code of my knock sensor not working, despite the light not coming on. I've done some digging around, and it looks like I have a sensor on the lower back of the passanger side block with the connector broken off of it. I'm guessing this would be my knock sensor, but I've also read here that 2.8l engines did not have a knock sensor?
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
Re: Knock Sensor
they do and that's it, well try hooking that connector up and do ur data logging again and see what happens.
Car: 85 Firebird
Engine: 2.8L
Re: Knock Sensor
Thanks, i'm going to have to try an get a replacement connector, the entire plastic part of it seems to be shattared and broken half onto the sensor, half onto the connector.
1 Post
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Knock Sensor
If this sensor in the block or the bottom of the passenger side head? THere should be nothing in the block over there, but the one in the head has a green wire going to it and is the fan override switch.
Car: 85 Firebird
Engine: 2.8L
Re: Knock Sensor
Its in the block, far back passenger side. A bit under all the EGR junk, and very difficult to really see or reach. I really need a good book to this car, does the GM shop manual cover in detail what sensors are on which year/engine combinations and so forth? The Haynes book is pretty useless in this fashion.
Re: Knock Sensor
Originally Posted by 2_point8_boy
That looks like a knock sensor alright, but yours is a 3.1L, right?
Car: 85 Firebird
Engine: 2.8L
Re: Knock Sensor
What I am seeing looks pretty much identical to this image.
There is also a single plug type connector that seems like it would fit this sensor, that has a single blue wire running back into the wiring harness.
The only major difference between the pic, and the sensor/plug/etc that I see is that mine has a much narrower plugin connector that is all metal, my guess would be that there may have been a plastic piece around this part of it that also is broken off.
Car: 85 Firebird
Engine: 2.8L
Re: Knock Sensor
Yes, I see that accept I think mine is a bit broken. However, this isn't suppose to exist on a 2.8 right? I guess I really don't know that someone hasn't swapped motors in it, though there are black gm valve covers with bright red 2.8 sticker on it, and the plenum has 2.8 marked on the top (would these swap over to a 3.1 block? )
Car: 85 Firebird
Engine: 2.8L
Re: Knock Sensor
Okay well, I'd gladdy accept having a 3.1 vs a 2.8, but I would like to know if this is indeed the case or not. Is there any way to verify what the block is without needing to find casting numbers on it? If I need to find numbers, where should I be looking? As my worthless repair manual doesn't talk about 3.1 v6 engines at all it seems.
