Replacement and Aftermarket 60* v6 parts
thnx to rsrsrs for reorganizing all the parts from the original sticky
can i get a mod to replace the current sticky with this new one
Camshafts
COMP Cams High Energy Camshafts: CCA-16-233-4 - summitracing.com
COMP Cams High Energy Camshafts: CCA-16-232-4 - summitracing.com
COMP Cams High Energy Camshafts: CCA-16-115-4 - summitracing.com
Delta Cams Regrinds And Custom Grind Cams (great prices)
Crane CompuCam Cam and Lifter Kits: CRN-254122 - summitracing.com
Crane CompuCam Cam and Lifter Kits: CRN-254112 - summitracing.com
Crane PowerMax Camshafts: CRN-253941 - summitracing.com
Crane PowerMax Camshafts: CRN-253901 - summitracing.com
Edelbrock Performer-Plus Cam and Lifter Kits: EDL-3790 - summitracing.com
Melling MTC-5: MEL-MTC-5 - summitracing.com
Clutch Kits
Centerforce Dual Friction Clutches: CTF-DF201901 - summitracing.com
Centerforce Dual Friction Clutches: CTF-DF201902 - summitracing.com
Computer Chips
Hypertech ThermoMaster Computer Chips: HYP-129322 - summitracing.com
Hypertech ThermoMaster Computer Chips: HYP-128932 - summitracing.com
JET Stage 1 Computer Chips/Modules: JET-18908 - summitracing.com
JET Stage 2 Computer Chips/Modules: JET-18908S - summitracing.com
Direct Replacement Cats
Catco Direct Fit Catalytic Converters: CTO-4115 - summitracing.com
Distributors
Mallory Unilite Performance Distributor: MAA-4569201 - summitracing.com
Headers
Pacesetter Headers: PSM-70-1206 - summitracing.com
Pacesetter Headers: PSM-72C1206 - summitracing.com
Ignition Stuff
Crane HI-6S CD Ignition and Coil Kits: CRN-6000-6302 - summitracing.com
MSD Distributor Cap and Rotor Kits: MSD-8430 - summitracing.com
MSD Blaster GM Coils: MSD-8226 - summitracing.com
Intakes
Edelbrock Performer Intake Manifolds: EDL-3787 - summitracing.com
Edelbrock Performer Intake Manifolds: EDL-3785 - summitracing.com
Mufflers
Dynomax Super Turbo Exhaust Systems: WLK-17493 - summitracing.com
Dynomax Super Turbo Mufflers: WLK-17739 - summitracing.com - cat back systems
Pulleys
Auto Specialties Underdrive Crankshaft Pulleys: ASP-541800 - summitracing.com
Replacement Carbs
Holley Remanufactured Carburetors: HLY-64-80081 - summitracing.com
Rocker Arms
COMP Cams Magnum Steel Roller Tip Rockers: CCA-1414-1 - summitracing.com
Suspension Stuff
Bilstein Sport Series Shocks: BSN-F4VE3C522H0 - summitracing.com
Competition Engineering Bolt-On Frame Connectors: CEE-3111 - summitracing.com
Edelbrock Adjustable Torque Arms: EDL-5282 - summitracing.com
Edelbrock Heavy-Duty Tie Rod Sleeves: EDL-5250 - summitracing.com
Eibach Pro-Kit Lowering Spring Sets: EIB-3801-140 - summitracing.com
Eibach Sportline Lowering Spring Sets: EIB-4-0138 - summitracing.com
Energy Suspension Hyperflex Bushing Kits: ENS-3-18131G - summitracing.com
Energy Suspension Hyperflex Bushing Kits: ENS-3-18131R - summitracing.com
Energy Suspension Motor & Transmission Mount Kits: ENS-3-1130R - summitracing.com
HAL Generation F Series Shocks: HAL-TC2502P - summitracing.com
Hotchkis Adjustable Panhard Rods: HSS-1501R - summitracing.com
Hotchkis Anti-Sway Bar Kits: HSS-2203 - summitracing.com
Hotchkis Anti-Sway Bar Kits: HSS-2236 - summitracing.com
Hotchkis Lower Trailing Arms: HSS-1301 - summitracing.com
Hotchkis Rear Suspension Packages: HSS-1801 - summitracing.com
Hotchkis Weld-On Subframe Connectors: HSS-4001 - summitracing.com
KYB AGX Adjustable Gas Shocks and Struts: KYB-735001 - summitracing.com
Lakewood Traction Action Lift Bar Kits: LAK-21700 - summitracing.com
Lakewood Rear Lower Control Bars: LAK-20140 - summitracing.com
Lakewood Drag Shocks and Struts: LAK-40500 - summitracing.com
Lakewood Drag Shocks and Struts: LAK-40510 - summitracing.com
Moog Strut Mounts: MOG-K6414 - summitracing.com
Moroso Trick Front Springs: MOR-47210 - summitracing.com
SLP Performance Parts Heavy-Duty Adjustable Torque Arms: SLE-70803 - summitracing.com
Suspension Techniques Sway Bar Sets: STQ-52075 - summitracing.com
Thermostats
Hypertech Power Stats: HYP-1000 - summitracing.com
Hypertech Power Stats: HYP-1018 - summitracing.com
Summit Thermostats: SUM-360160 - summitracing.com
Summit Thermostats: SUM-360180 - summitracing.com
Summit Thermostats: SUM-360195 - summitracing.com
Torque Converter Applications
TCI Auto Torque Converter Chart - PN 243200
Tubular K member, RCA, PHR, Coilover Conversion, Tubular Front Control Arms
American Race Components
Camshafts
Clutch Kits
Computer Chips
Distributors
Headers
Ignition Stuff
Intakes
Mufflers
Pulleys
Replacement Carbs
Rocker Arms
Suspension Stuff
Thermostats
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: Replacement and Aftermarket 60* v6 parts
Good post, Dave. Do you have a source for high compression pistons?
sjorgens
10-01-2015 07:54 PM
Damon
09-26-2015 04:29 PM
