At A Stop Car temperture Starts To Rise???????
Old 04-22-2007 | 06:40 PM
redline_racing's Avatar
Hello,since the good wether v6 is acting up while i'm driving my car temp is fine the minute I stop for a long period of time like at a stop light the tempertur gauge starts to rise 220 but by the time the light is green i take off and it starts to go back down will someone help with this problem all fluid are proper no leaks ?does this sound like a bad thermostat to guys.
Old 04-22-2007 | 06:53 PM
Digital8's Avatar
Car: 84 Camaro Berlinetta
Engine: 350 4-bbl
Re: At A Stop Car temperture Starts To Rise???????
It does sound like a bad thermostat. I would try the easy fix first. If that doesnt work to good have your cooling system flushed. Good luck
Old 04-22-2007 | 07:01 PM
daves12secV6's Avatar
sounds more like the fan isnt comming on then a bad tstat.my car used to do the same thing
Old 04-22-2007 | 07:05 PM
but how come when start moving again it comes down and level itself out?I have a new thermo to put on but im affaird to put it on because there are soo many pipes running bext to it can i take them off?
Old 04-22-2007 | 07:08 PM
when u come to a stop there is no air moving threw the radiator,thats why the car has a fan.i can run my car all day long on the highway without turning the fan on and it wont go over 165* if i come to a stop and dont flip the switch for the fan temps will go up over 220* in a hurry but will drop again once i start moving
Old 04-22-2007 | 07:16 PM
so check the fan?also will it overheat on my on the highway? it never sat long enough to go way over the 220 marker?
Old 04-22-2007 | 07:33 PM
pairtoe's Avatar
yeah, i had the same prob last summer, ended up replaccing everything, then t-stat, radiator, fan, then still acted up so i got a new water pump, when i took it off the block the inside propeller wasnt even attached to the water pump, now it sits at about 165.
Old 04-22-2007 | 07:40 PM
even though i cool back off while driving?
Old 04-22-2007 | 07:42 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Sounds like a fan problem...
Old 04-22-2007 | 07:52 PM
pairtoe's Avatar
yeah, let your car warm up, then pull over somewhere pop the hood and see if the fan turns on, or you could just hot wire it.
Old 04-22-2007 | 09:11 PM
firstfirebird's Avatar
Just start the car and let it idle with the hood open. Watch the guage and when it reaches aprox 190*, the fan should turn on (maybe 200* according to the stock temp guage). Before changing the water pump in my car, it would sit right at 200* to 220*. Since the new pump and 180* t-stat, it stays at 180* all the time now.
Hope that helps .
Old 04-22-2007 | 09:27 PM
i hope its not my water pump?is it hard to replace myself?
Old 04-22-2007 | 09:41 PM
Not really, but make sure it is your pump before making any assumptions. First start the car like
I said and see if the fan is comming on. If the car runs hot (past 220*) and you don't hear the fan it is going to be the relay or fan motor. If the fan is comming on (and the pump isn't dripping) check your t-stat (if you take it out to check, might as well replace it, they are like $8). The next step is radiator cap (about $4). Then water pump (about $30).
Also if you want to save some time and money, make sure the system has nice and green fluid in the radiator. If it is brown and nasty, flush it before anything else, and test by letting idle.
I suggest you spend the $15v on a Haynes or Chilton manual and read it cover to cover and all the basics are in there if you are not mechanically inclined and want to learn .
Old 04-23-2007 | 09:31 AM
ok here's the deal I turned the car on and let it run and at 180-220 the fan doesn't come on how do I hot wire the fan or make it come on also if i have to replace it where could i buy one from?
Old 04-23-2007 | 09:41 AM
pairtoe's Avatar
just go to autozone or napa, and pick up a new fan motor for about $20. and then swap the old one out for the new one. heat the car up again see if it turns on, if so you should be good to go. you dont really want to hot wire it though becuae if you leave the fan running all the time it will burn out the motor much quicker, so far every summer i have gotten a new fan motor for my car becuase of this.
Old 04-23-2007 | 11:30 AM
dont do this, more then likely its the sending unit for the fan, when i get out of work i will post up pics of how to hotwire the fan using a 2$ toggle switch
Old 04-23-2007 | 01:59 PM
thanks i wont those pics dave lol
Old 04-23-2007 | 06:16 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
I have the same problem the OP is having.
I had replaced the relay that is attached to the firewall. Started the car up, it got warmed up and the fan kicked on.
But
Now when the temp gauge goes a little bit above the first line the check engine light comes on. I'll drive, the needle goes down, the check engine light goes out. Ugh, I hate cars sometimes.
Old 04-23-2007 | 06:50 PM
whats the op?
Old 04-23-2007 | 06:53 PM
op = original poster
i cant find the pics, but if u do a search on my user name,u will find them the post will be a year or older
Old 04-23-2007 | 10:26 PM
can i drive it will it overheat ?on me im scared as hell to drive it?
Old 04-24-2007 | 06:01 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Water pump is easy, just a few bolts and hoses and it comes right off. Lots of room to work on it, too.
Kevman's Avatar
Engine: 2004 LQ4
Double Post
Old 04-24-2007 | 07:11 AM
pairtoe's Avatar
you can drive it, but you have to watch the temp guage like a hawk if it goes past 220-230 turn it off asap, i would suggest not to drive it but if you got to.
edit: i would also suggest buying an aftermarket temp guauge for like $15 at autozone or napa, this way you know exactly what your temp is. they are very easy to install.
Old 04-24-2007 | 01:49 PM
ok check this out i turned the heater on first drive dam near all day with the heat on killing car temp was between 180-220 all day it never reach over 220?other question someone told me to turn on my a/c and run it same thing car sat between 180-220 and the temp was at around 180'ish and i turned the a/c off 2mins later fan turned off is that normal and will it over heat?and whats the problem?
But
Where's the relay and could you describe it?
Last edited by redline_racing; 04-24-2007 at 01:50 PM. Reason: Automerged Doublepost
Old 04-24-2007 | 03:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well I didn't see this mentioned yet, but:
Did you check the coolant level? Your radiator isn't running dry, is it?
Actually I think the water pump is a real pain to change. The actual replacement isn't bad, but scraping off the old gasket while trying not to gouge the seal's surface on the aluminum timing chain cover- that's the pain. I've done that job 5 times already.
If you do change the thermostat, take a drill and put two small holes "north and south" in the edge of the thermostat's ring. These will help keep air pockets from forming underneath the thermostat.
You could also remove the radiator cover (across the top of the radiator) and make sure there's no piles of leaves or dead bugs between the front of the radiator and the back of your a/c condensor. That won't help when the car's stopped and idling, though.
When is a 3.1's fan supposed to kick on anyway?
Old 04-24-2007 | 04:02 PM
thanks >?
Old 06-23-2007 | 03:51 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
even if your fan(s) are running, low fluids will do this also. the fans aren't strong enough to keep that little bit of fluid that you may have in your radiator cooled, but when you start moving again, that stronger airflow will cool you back down quickly. I found this out a few days ago when my heater core leaked out most of my fluids, core is now bypassed and I expect no further problems being that my fluids shouldn't be escaping anymore.
Ghettobird52
07-05-2024 11:18 PM
Wade787b
09-29-2015 01:15 PM
TheExaminer
08-26-2015 04:59 PM
Ginamariegault
Brakes
08-10-2015 08:33 AM
hokis
08-09-2015 03:57 PM
Quick Reply: At A Stop Car temperture Starts To Rise???????
