for those who have headers
Car: 89 Camaro RS, 99 Sunfire GT
Engine: 2.8L, 2.4L
since it's coming close to getting the camaro back on the road, I have being polishing up some things, and I got my engine bay looking SUPER clean. Last summer I installed a cat-back exhaust and put a high flow cat to give it a nice grumble to the V6... alot of people tell me it sounds like an 8. I would like to know from those that have headers on there V6, if it does a difference in sound and if you could also post a pic to see the difference in looks (im sure it looks way better then the old brown manifolds.
thanks
thanks
Car: 89 f-bird and some others
Engine: 3.4
I have a 2.5 in system from the cat on back with a dynomax muffler. It sounded pretty good before the headers, and became quite a bit louder after installing the headers.
A little too loud for me at certain rpms while accelerating, but sounds nice most of the time. The exhaust note rattles a lot more stuff in the car now too.
I tried to post a pic of my engine, but I already posted it during the installation several months ago, so it wouldn't let me do it, and searching for the thread didn't turn up anything for some reason, so yes, it does look better.
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Here is what mine look like now. I love them minus the bolt that I forund was broken when I went to take the manifolds off.
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Re: for those who have headers
Ok I have the headers on my 3.1L. The car at idle can sound like a 5.0 (305) but at higher RPM's the exhaust gets raspy and sounds bad but you have to expect that from a 189CU V6 motor with headers and a V8 muffler on it. I wouldn't worry about the sound its just a lil louder than what your car is now. The rumble the exhaust puts out is enough to rattle my house when i start it up. From the headers the exhaust goes into a high flow cat 2.5inch dynomax mid pipe and a flowmaster 80 series muffler. One more thing the headers look much nicer than the manifolds but you should put some type of coating on them because they will rust withing a week.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
search ebay user "........" and there are 3 pics of my engine bay up there showing the headers. You could more then likely search on my user name here and find some of mine.
I noticed at idle it gave it more rumble, but at wot it sounded worse.
Car: 89 V6 Camaro
Engine: 2.8
I wish I did that. As soon as you crank your motor for the first time with the headers on the paint is already burning off. Don't worry if you get smoke for a few minutes with them first on.
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
Definitely louder, my car sounds bigger than it is at idle. I live in an apartment complex and since I've installed the headers (already had high flow cat and catback) my geriatric neighbors have been complaining to management a lot more. Been here since July last year and management has file full of noise complaints . The only thing I dislike is that they sound a little raspy at higher rpms, but I'm hoping that can be fixed with a resonator.
im going to go against the norm here, i didnt notice much of a difference in sound when i put mine on. i noticed a bit of sound and performance difference, but not a whole lot. although, i am running a 3.4, so that may have some to do w/ the performance part of it.
Engine: 350 S-TPI
If you think that it would pass noise level according to police. Go up to the PD, or state inspection station and have them write a letter saying that the car passes the DB level. Complex cant do jack $hit.
Engine: 3.4
I'm thinking about getting a quieter muffler actually when it comes time for it. I'd like to stay with the 2.5 in. I'll have to do my homework though on what's the quietest. At the moment I have a dynomax.
Engine: 350 S-TPI
dynomax is the quietest from my findings. Sounds like you have almost the same setup as me.
If there complaining about that, there to old Even my 55yo dad likes the sound of the dynomax.
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
drdave on your 3.4L do you have your headers hooked up to your stock exhaust system. If so the stock muffler and size wont allow for much of a sound or performance change
Engine: 2.8L, 2.4L
no, my headers connect to a Catco converter and then to the Dynomax cat-back. it will change performance because the most restrictive part of the entire exhaust system is the manifolds, well unless you have a plugged cat. ive gotta imagine that the performance and sound would still change, but probably not as much as it would with a cat-back and a new converter.
I have info on this page that will help with advice. I have tried several different things on this car over about 15 years before and after header install. What worked great before header install was obnoxiously fartcannish after header install. This new setup was tailored out of a few different tries after header install and I finally nailed something I am very happy with.
http://www.cardomain.com/ride/518752/5
Grade 8 is the hardness of metal. You can find grade 8 bolts at any industrial hardware store. You don't need to spen money on fancy locking header bolts, they are actually a PITA to retorque. The problem alot of hotrodders have is not retorqueing the header bolts after the first time they drive the car and get things up to operating temps. Its a pain, but you should realy try and retorque them when they are warm because they loosen with heat applied so get the motor hot then retorque them when it cools a little but is still on the very warm side. I forget the size and pitch of the 60*V6 studs but I thnk off hand they are 10x 1.25 and should get bolts about 1 1/4 inch long for headers.
I personally rub a dab of copper antiseize header sealant on my bolt threads before installing.
Car: 83 Firebird
Transmission: 2004r
Axle/Gears: 10 bolt posi 3.08
If I run my v6 long I will want a set of headers, cn anyone recomend a set and where to get them?
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
Engine: 350 S-TPI
or in possibly 2 weeks, I will now where the very first set of pacesetters will be forsale.
Car: '88 Camaro
Engine: v6-173-2.8L
Pacesetter is the only brand that makes headers for our car. I bought the stage 8 locking header bolts, but they were the 8mm x 1.25, I don't believe they sell stage 8 in 10mm x 1.25.
Yes and no.Technically, they are the only smog legal ones if you are subject to smog inspections. Otherwise, Hooker and Hedman both made headers that are still ocationally found- I sold a set of each of them a year or two back to other members.Also, PF&E in Michigan makes custom stainless steel headers that are far nicer than the pacesetters, but trying to pass smog is a little more tricky.
Car: 83 Firebird
Transmission: 2004r
I just looked on summit and find NOTHING for the 3.4 for headers, so can anyone tell me a different way to find them?
Engine: 350 S-TPI
They make 3.4 ones for the 4th gen f-bodys.
If your putting them in a 3rd gen, you need to get the 2.8 3rd gen ones.
1 Post
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
I stripped mine, and then painted with high temp paint. You then have to bake the paint on basically cure it with the engine heat. Run the car a few minutes let it get up to temp then shut her off for awhile. Do this a few times and your paint wont flake off and your headers wont rust. Mine are still black a few years later (matte black anyways)
Car: 83 Firebird
Transmission: 2004r
http://store.summitracing.com/partde...5&autoview=sku
Yes I looked them up using make model and so on, if you do an engine search then they come up fine.
Last edited by Gottork1967; 03-29-2007 at 11:43 AM. Reason: hit the post button before I was ready
Car: 1989 Iroc z28 TPI Camaro
Engine: 350 5.7 TPI
lots of people in my town have third gens and most of the people around here are gear heads theres this one camaro that everyone knows about with a 6 with exaust and headers and my friend said they should get a ticket from the cops for false advertising lmao... they sound like a 8 in idle but as soon as they get on it sounds like ****.. dunno myself i cant do less than an 8 and if you got a cam with a 6 around here you get made fun of but if you dont gatta worry about that by you i say stick the headers on...
redformula88
10-14-2015 06:08 PM
