300hp out of 91 3.1l v6??
My friend and I are gonna try to get 300hp outta my v6. What do you guys suggest we do first along with easiest and cheapest mods. OR whether u think we can do it.
Car: 83 v6 firebird
Engine: None right now
Transmission: none right now
Axle/Gears: 3.08 one tire fire
start with getting rid of the iron heads and getting some gen III alu. heads, good cam, good bottem end, headers... 300 is going to be a stretch but their are quite a few people on 60degreev6 getting 200+ at the wheels N/A
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
go get a fwd 3.1(or 3.4), refresh the block, redrill for RWD starter, custom cam, FWD ported heads, ported intake, full exuast from the heads to tailpipe, stand alone ECM system with coil packs, then turbo.
Redrilling the starter is not as easy as it sounds, if a genIII block is used, whihc the genIII has the best flowing heads/intake so it woud be the best start, the crossmember and/or oil oan will need to be modified extensivly, you can't bolt a RWD oil pan ont the block due to different bolt pattern on teh block and the crossbolted mains that bolt to the oil pan. Custom left side mount, and a few other custom parts.
If you don't mind all of that, and having limited cam selection, go for it.
I would probaby build a hybrid, using a genI block, preferable a 3.4 block from an F-body, as it will have the crank trigger provisions already, bolt into the 3rd gen, and then use the genIII 660 top end to make it breath like you just took a bunch of antihistamines.
Car: 92 Firebird
Engine: 3.1
Axle/Gears: stock, dynomax turbo exhaust
If he can do it.
You need to talk to Dave (Daves12secv6) if he can do it I don't see why you can't, as long as you have the money of course, all you have to do is buy the turbo kit from him and then have someone install it for you. You should make 300 or somewhere close, either way you will have the fastest V6 Bird on the street if you put that turbo on there, just get some info from Dave and I'm sure he'll fill you in.
Car: Blue 89' RS
Engine: 5.7L
you can get ~350-400 horse out of a 3.1, or more.
the easiest way is:
forced cold air intake
bore out 30-60
head work/better heads
headers
prom work after its all done
msd 6 or 7
keep adding bolt ons from jegs/summit
i made a picklist... and from my 2.8 i range from 350-420 hp... now, i haven't done anything yet, its just a list
the easiest way is:
bore out 30-60
headers
msd 6 or 7
Car: 88 camaro
Engine: 3.4
Transmission: t-5
Axle/Gears: limited slip posi 3.42
350-420 horse are u serious i'd like to see a dyno result when ur done but that's insane i got my v6 cause i don't want to be paying a fortune in gas but if i wanted hp i would of got a 350
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Different people have different goals for their cars/engines. Some people like to do the "cookie cutter" approach and slam in a v8, and some like to be different and make their v6 go fast.
But for 300hp------> Forced induction plus a bunch of other mods like stated above.
Car: Blue 89' RS
Engine: 5.7L
as well as you have the pistons, cam, head work, and maybe even new rods for the pistons. part of the head work would be to apply new/better springs for the push of the overbored pistons. the forced cold air intake adds a good amount of horse and is one of the cheapest and easiest bolt ons as long as you know what to do with the sensors. also with the headers, go ahead and run true duals, cats if needed, straight pipes if not.
also putting on headers adds a lot of horse. putting in better gears and building the tranny also helps a lot. the msd and prom burn are needed later to take up the slack from the the performance enhancers. also you may need to get a better distributor. the best thing to do is buy everything and when the block is out getting bored and honed, put the add-ons all in that you would have a pain getting to. so if you need to do any tranny work, or distributor (you know its a pain to get to our dizzys), or whatever, change out this or that... do it. i already upgraded from my stock radiator (v6 iron, or whatever that heavy crappy thing was) to a v8 aluminum. i made my own hose lines with pipes, and i was good to go. just go nuts. we v6's don't need a gas hog to get hp, we can get it through mods. be proud of your v6 with *****... or get a v8.
2.8 comes with ~135 hp stock. if you look at jegs/summit and add the +from stock on your mods... its easy math. go take a look some day.
You can't be serious?
Adding advertised HP numbers from the sumit catalog to the stock HP, is just foolish.
There is no way, and this has been proven, to gain hundreds of HP from mere bolts ons bought from a catalog, on ANY engine (well diesels excepted).
The only way I've seen anyone get 300+ HP from a 660, is through forced industion, usually turbo, plus usually a few other changes, like better exhaust, larger injectors, etc, oh and this is with the genIII heads, most genI headed 660s don't break much over 250ish, with a few, VERY few exceptions to thei rule, Tiago, Curtis Walker are a couple that come to mind, both heavily modified with huge porting, and in Curtis' case many bottom end upgrades as well. Both were turbocharged using rather larger turbos and both were using 3.4 F-body intakes. Oh and the boost levels were high, 20ish+ PSIG IIRC.
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
lmao.........thats the best joke ive heard in months.
lol, that was good, wow. so i should be sitting at leats 250-275hp by now. would dragon seat covers, stickers, and a wing help me too?
ok, gears arent gonna add power at all, neither will msd or any ignition stuff, all those do is help you get the most out of what you have. headers may have added 10-15 AT MOST to a modded engine. i put mine on and hardly felt a difference at all. its too early to keep going, lol, but that was good to wake me up, wow.
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
Re: 300hp out of 91 3.1l v6??
well believe it or not I saw a it had to be an early 90s model ..3.1 z34lumina that was twin turbo getting 342 rwhp at my mechanic..I..I dont like luminas but i gave him props..the point is that he put alot of work into that car i dont know why paint rims racing seats and engine mods but it was still a 3.1 meaning that must be possible to do it in a cam if he found space for 2 turbos anything is possible
It is up,but we're talking about a 3.1 and in all my searching I've never seen a 3.1 make even 300 hp na,must less 400,but would be interested in seeing the details.
Car: 1986 Chevrolet Camaro Z28
Engine: 383 Stroker
Axle/Gears: 7 1/2 Inch 3.23
Haha... Rename this one the Bullshit thread...
Why? Are you also a non-believer?
The origional poster didn't say anything about staying N/A, only no NOS. And the 60* site is still down
All I can say is: Dave, you must post some dyno results on your new motor!
I think I can get at least 400 with a turbo, perhaps we will see...
I asked my mechanic about what engine it was to make sure it was a 3.1 it was 90 cavalier z24 this model : http://sky.prohosting.com/tmhardy/other/8890/mamak.jp I just thought it was an 90s luminda with a 3.1 thats why it was crazy how he fit those turbos in there ..the point is if mitusbishi can make a 2.2 engines at almost 300 hp who says you cant take a 3.1 and do even better
"The origional poster didn't say anything about staying N/A, only no NOS. And the 60* site is still down " Damn ! Your right, I'm spending way to much time on this computer. My most humble apology to all.
Here is the page:
http://community-2.webtv.net/cumonbaby/TwoCumonBabys/
The thread that I was mentioning:
http://60degreev6.com/showthread.php?t=25356
HoosierinWA
10-07-2015 10:15 AM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
