Car stops at red light
Car: 92 Firebird
Engine: 3.1
Axle/Gears: stock, dynomax turbo exhaust
Hey guys I have a little problem, I have taken my car to several mechanics and no one seems to know why my car keeps on stopping at red lights, it starts fine and runs fine but as soon as I stop at a red light, it sounds like its about to turn off and sometimes it does, it turns back on right away. First I replaced the starter, it wasn' that. Does anyone have any recommendations on what it can be? Thanks. 92 Firebird.
Car: 1986 Trans Am
Engine: ZZ4
Transmission: TH700R-4
Friend of mine had the same problem with their Taurus a while back and it turned out to be a plugged fuel filter.
Hope that helps.
Hope that helps.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
your supposed to stop at red lights... lol
Car: 92 Firebird - 97 Talon TSi AWD
Engine: Firebird: 3.1L - Talon: 2.0L
Transmission: Firebird: 700r4
I was waiting on somebody to say it. lol
Here, read this one and see if any of those things solve your problem. I bet one of them do solve it.
https://www.thirdgen.org/forums/v6/3...ough-idle.html
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Aww crap guys, Never knew stopping at red lights ment a mechanical defect in my car. Where should I start looking for this problem?
1 Post
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
I keep trying to stop, but my car won't let me. Scares the SH** out of me!
And, by the way, if the car starts, the starter isn't your problem. Seriously though, it may be fuel filter or fuel pump, let us know what it was when you determine the problem.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well vacuum leaks will also do that. Power brakes use allot of vacuum. If you have a leak, a sure sign is when you apply the brakes the engine dies or tries. Its cause the brake booster is sucking the life out of the engine trying to get enough vacuum, but its can't cause of the leak.
knowing your vacuum situation can reveal all kinds of things about an engine.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
A malfunctioning vehicle speed sensor can cause the car to die at idle also.
Car: Camaro -88
Engine: 2,8 V6
Axle/Gears: yep, got that as well
Had the same problem on my camaro but that was because the generator was malfuctioning.
I could see that the volts dropped and then the revs began to decrease and well, the car died.
So a generator swap helped.
off topic:
woo first post here! sorry for my language, not used to talk about cars in english
off topic:
Car: 92 Firebird
Engine: 3.1
Wires and Plugs
Yeah I used to be the same way, Red Light, what's that? Until I got caught a few times by red lights on a black and white car, they taught me right away what a red light was, ever since I have used that ingenious invention to my advantage but now my car stops, go figure I guess you just can't win. Anywho! Thanks you guys for the recommendations. You would think a mechanic would know that, I know their hood mechanics but still come on.Ok I'm new to the car enthusiast thing but when you say replace the plugs and wires what do you mean exactly? The wires that connect to where and the same for the plugs, and excuse my ignorance. LOL.
Car: '91 Pontiac Firebird
Engine: 3.1l V6
Transmission: Automatic
Axle/Gears: those that came in the car
If it runs fine otherwise and is a fuel injected engine, you might try taking the plastic hose off of the front of the intake and clean the carbon build up on the edges and back side of the throttle plate / valve. I'm not really sure what it's called but I've had a similar problem with GM and Ford vehicles where there should be a slight clearance there in the air intake but the little bit of carbon build up is enough to choke it off when you come to a stop. I don't think you should spray carb cleaner in there (I think it's the MAP or MAF or something) but rather spray some on a clean rag and wipe the black carbon off of the big butterfly valve.
If this doesn't make sense, I'll try to post a picture.
Car: 92 Firebird
Engine: 3.1
Vacuum?
Vacuum? Yeah just today I was going to Downtown (L.A.) and it stopped at a light, its starts to accelerate a little like voom voom by its self and suddenly it stops, I can turn it on right away but sometimes it stops as soon as the light turns green and I can't stand when people start to honk at me, so I am pretty desperate to fix this problem. So far I've got that it can be the wires and plugs, distributor Cap and rotor or THE VACUUM? What you mean by the Vacuum? Thanks fellas.
Car: Blue 89' RS
Engine: 5.7L
vacuum usually is a vacuum leak... in a rubber hose. i think it cost me $14 and 1 hour to replace (buy and replace myself) all of my vacuum lines except for the hard plastic ones by the EGR (passenger side of engine by heater core and heater valve... and overfill tank for radiator).
Also one thing that kept making my car die was a $0.50 piece of rubber connector. it had dry rotted... it was at the end of one of those hard plastic vacuum hoses that plugged into a sensor. i got some vacuum caps for the small plastic vacuum tubes and cut the end off of the cap (cheapest way) and stuck it in place of my dry-rotted one. it was an easy fix
edit: Also if you have cruise control (whether it works or not) under the driver side nose of your car there should be a ball hooked up, a hard plastic ball. There is a vacuum hose going to that ball as well... make sure it hasn't dry rotted/cracked or come loose. if you are replacing vacuum lines, replace that one while your at it... and make sure all condensation is out of it.
Until you fix your dieing problem... use your left foot for the brake and use your right to apply a little gas so you don't die at a stop light/sign. Also, make sure you have good/new air filters. When was the last time they were replaced?
Car: 1991 Firebird
Engine: 3.1L
Transmission: Stock
Axle/Gears: Stock
Speaking of Vac lines. Could someone with a '91 or '92 3.1 post a picture of the vac lines coming off the back of the intake? Cant figure out which one goes where.
Car: 92 Firebird
Engine: 3.1
Cross my fingers.
Thanks guys I'm going to try this week replacing the plugs and wires and if that doesn't work then I'll try replacing the distributor and rotor and finally I'll try replacing the vacuum tubes if everything else fails. Thanks a lot for your opinions, I'll tell you how it goes.
Car: 1991 Camaro RS
Engine: 3.1mpfi swapping in a 2.8mpfi
Axle/Gears: non-posi rear
there is only 1 hose that NEEDS to be plugged into the back of the throttle body.
Car: 1991 Firebird
Engine: 3.1L
Transmission: Stock
Axle/Gears: Stock
I appreciate the effort, its more than anyone else did, but I didnt ask about the throttle body, i was asking about the back side of the intake....by the distributor.
Car: 1991 Camaro RS
if nothing else ill draw a pic of it for ya and explain where everything goes, give me 2 days.
Ghettobird52
07-05-2024 11:18 PM
