performance v6
Car: 88 IROC Z
Engine: 5.7
Axle/Gears: 3.27 9 BOLT POSI
performance v6
i have an 89 v6 and i was wondering what i could do to get more hp out of it? anybody have any suggestions?
Car: 1985 Firebird
Engine: 2.8L V6
Transmission: stock auto
Axle/Gears: stock
Read the Sticky forum at the top of the V6 board that will get you to a good start. Im also looking into getting more horses out of my V6. good luck
1 Post
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
u can always do what me or 3 other members have done and build urself a turbo kit.the cheapest bang for the buck by far would be a nitrous setup,though for another 200-300 u could build the same turbo setup i did,if u have access to tall the tools.
other then that
first things first full tune up make sure its running great,simple start would be k&n's and a cat back ex,theres always headers,camshaft and computer tunning,though steping up the gear ratio in the rear makes a big diff
other then that
Car: 1990 Firebird
Engine: 3.1L
Axle/Gears: 3.23's
So you put a turbo on your stock v6? Without changing any internals. I was looking into it for my car then someone told me the engine would hold up to it and I would start having some internal problems. If you could let me know what you changed if you changed anything internally, thanks.
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
no daves12secV6 has changed his internals... i think. he will chime back in.
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
yes i truly idolize the folks running turbo's
i did change my internals only cause i run very high boost levels,but u can safely run 7-9 psi on a stock engine as long as its in good shape.i belive on of the other members here runs upto 12 psi on his stock internal motor.
the only thing i changed in my motor internally was i replaced the stock pistions with custom forged pistions.other then that its still a stock crank/w redone stock rods with arp bolts
Car: 1990 Firebird
Engine: 3.1L
Axle/Gears: 3.23's
Alright, yeah I would say my 3.1 is in pretty good shape. Theres 65,000 miles on it and the owner for the first 57,000 was an older person and never abused it. If you could send me some pics of how you set up your tubo I would apperciate it. Thanks
https://www.thirdgen.org/forums/v6/3...ing-turbo.html <---theres his turbo write up w/pics
1 Post
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Yeah, I think that Doward is running stock pistons in his motor...techsmurf is too, right? I have a nice set of custom forged pistons waiting to go in my 3.4 for my turbo setup, though.
doward i know was running stock pistions till he broke a ringland,not sure if he ever got it back together.techsmurf im unsure of.there wa sa guy running 14 psi on a bone stock bottom end 3.4 and never had a problem.
i went with forged pistions in mine just due to the fact im running in exess of 16psi and plan to spray nitrous
Pac J
05-17-2020 10:44 AM
