V6 Exhaust Sound Clips
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I don't think anyone has posted any before, or at least my search didn't turn up any threads with V6's. Im looking for a 3.1L V6 with a nice exhaust. I want to get a Magnaflow (I recently purchased another V6 to swap into my Firebird because I really miss driving her. This way I can enjoy her while I build my V8), but Ill take sound clips of anything.
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
I got one on street fire but its from inside my car.. Its of a 2.8 with a hollowed cat and no muffler..
Car: 1991 Firebird
Engine: 3.1L V6
Magnaflow or Dynomax I heard sounds good on our cars. But the Flowmaster is too raspy and high pitched.
V6 Firebird - dcfn0001.avi @ ZippyVideos.com - Free Video Webhosting
Flowmaster - got this one off a guy on cardoman...convinced me to never put a flowmaster on my car.
Car: 1992 Firebird
Engine: 3.1L V6
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Video - 2.8 V6 Camaro with a glasspack....
Im gonna get another one from outside today hopefully, if not Ill deffinately have one tommorrow.
Car: 1991 Firebird
Engine: 3.1L V6
Well its raining and my fuel rail is pissing out more gas than whats going in so gonna be a couple days but Ill deffinately get them up.. Ill take some with my resonator too but it doesnt sound as mean..
Car: Blue 89' RS
Engine: 5.7L
How much did your glasspack cost you? ... Sorry to be a nub, but what exactly is a glasspack, and what did you have to change out in/around/on the pipes/muffler/cat convertor?
Is it street legal? Did you keep the cat? Dual Cats? Did you keep the muffler? Dual Mufflers? Do you have Dual pipes at the rear?
...biggest of all: Do you see smoke/crap out of the tail pipes or is it clear?
Thanks,
ScottieB
Thanks,
ScottieB
It cost me roughly $30.. A glasspack is basically a hollow pipe with some baffling in it, to my knowledge atleast.. I put it in place of my cat.. It is street legal for me, depends on your state/laws.. No cat, no muffler 2 1/2 inch mandrel bent pipe after the glasspack exits where it would connect to the muffler.. No smoke or anything unless I downshift or it backfires.. Be prepared to hear alot of backfiring when downshifting.. There are some loud ones so try not to get scared lol
Car: Blue 89' RS
Engine: 5.7L
My grandpa is a welder, so it wouldn't be too hard to fit it in
I have no clue, I assume it would sound differant.. I dont think Texas cops would mind, but I dont know the laws there, best bet is to go ask a cop whats legal and what isnt..
Car: Nothing stock- I screw with everyth
Engine: Hook&Ladder #8
Transmission: Morris Code
Axle/Gears: AxleROse CD Collection & Scuba Gear
Put a load on the glasspack @4000rpm and up going down the street from behind the car and I garantee it sounds like crap- beware buying one.
Ill get a couple videos as soon as the weather clears up so I can fix my gas leak..
Well theres supposed to be briefly sunny today so I might get those sound clips sooner that I had expected.. Gonna go start working on the fuel rail now since its decent out...
Car: 91 Pontiac Firebird
Engine: V6
Transmission: TH700R4
Dynomax ultra-flo and flowmaster
I'm sure they got posted on here before, but here are some clips of my 3.1L Firebirds.
The first is with a Dynomax ultra-flo cat-back system
Dynomax
This is my other Firebird with a Dynomax intermediate pipe, flowmaster muffler and cat-delete pipe :
Flowmaster
I prefer the Dynomax.
Dynomax
Flowmaster
Car: 1991 Firebird
Engine: 3.1L V6
I think that Dynomax inter pipe flowmaster muffler and cat delete pipe sounds deeper and a bit more aggresive than the Dynomax. The Dynomax sound clip makes the car sound like an astro van.
Here's what a V6 should sound like over 4000 rpms. Notice you can feel the power of it in your chest- its not raspy at idle nor at high revs. NOTE: The ambient humming noise is the electric fans going. It was 103 here in So Cal this afternoon and still very warm tonight. The wife just got back from running around in this car with the A/C on so both fans are humming when I just restarted it in the garage.
In case you have not seen the cooling system on this car, or the single 2 1/2" exhaust exit though a 28.5" long Stainless Works custom made baffled muffler in place of the I-pipe and a little 10" long Cherrybomb turbostyle muffler hanging in the rear with minimal exhaust weight compared to a stock f-body setup.
https://www.thirdgen.org/forums/atta...g?d=1149563885
EDIT: Link is temporarly not working- I'll get it back up ASAP
Car: 1991 Firebird
Engine: 3.1L V6
DRR, do you have any from outside of the car?? That's also not in the garage(it makes too much echo.) That sounds like my car(it's stock) from the inside. The stock exhaust sounds good, best i've ever heard on the V6's actually, just not loud enough.
hey heres some of mine i took today. mind u this is 2.5 inch ex with dual 3 inch tail pipes 80 series flowmaster,on a turbo charged engine.now theres 2 clips . the sound is a lil ****ty cause i had the laptop i used to record the sound to close to the tail pipes.but it will give u a general idea.btw when u hear it rev slightly.but it gets supper loud for a second,its cause for some reason @ about 1,800 it resonates pretty bad but it quiets back down above 2k but its gets real tinny above 5,000 as u will hear.IMO with load on the engine it sounds alot better,and dosent sound ricy/tinny at high rpms.im swaping my flowmaster for a spintech muffler,or a adjustable borla system not sure on which yet.anyways heres the clips
http://2wai.ics-il.com/sounds/startup1.wav
http://2wai.ics-il.com/sounds/startup2.wav
btw if u listen carefully u can hear the turbo winding up a bit
Car: 1986 Trans Am/1993 Trans Am
Engine: 305 .030 over built/ LT1 Bolt Ons
Transmission: t5/700r4
Axle/Gears: 3.43 Posi/3.23 Posi
ok a glasspack is a straight thru muffler with fiberglass in it, so its louder and if your state is strict on emissions and crap then its illegal. Go with a Dynomax.
Here is the obnoxious Flowmaster when I was racing it. This video sounds true to what the car sounded like (not my carmera- thats probably why- my mic is crap.) This car actually sounded decent with the flowmaster 80 and with most importantly very small 1.75" dual tips rather than the obnoxious 2.5" exits. However, in the autox video I had just put Headers on the car and it elevated the flowmaster resonation- I could not stand it and change it to the current above.
Here's the motor under high rpm loads (incar). I borrowed in from the wife this morning to run an errand. This is a high speed stop form 5800rpm in 2nd gear (85mph) Then turn the corner and acceletarate back up to 70 [4800 in 2nd] before having to slow-(There is a school zone on this road 3 corners ahead- Notorious for cops sitting there). Note that the braking is done DOWNHILL! You get an idea how fast this car stops. These tires are terrible compared to the Goddyear GS-D3's I just replaced- These are crappy BFG KDW tires, I hate them). Rearend gears are a lower 3.23 and this is a very radically built 700r4 (No a shiftkit package- a ground up all out performance build with all the latest and greatest in it- here how quickly it shifts) I am also trying to hold the camera on the dashboard with one hand while driving.
Originally Posted by 1988CamaroSC
why cant i get sound on any of the vids drr? is it my comp?
If you want, I will e-mail it to you. Just let me know if any is interested in hearing it. This car is still slow, but is amazingly peppy for a little 2.8 V6 F-body compared to stock ones.
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
all of them worked fine for me except the racing one.
Off topic for a sec...DRR, I remember seeing a post from you recently that had some info on your driveshaft and axles and stuff...can't find it again. if you know which one i'm talking about, could you point me in the right direction?
As for axles, Mine are Moser 26spline tapered axles and the flanges have been also drilled for rotation lightness. I added the ARP 1/2" wheelstuds because I corner hard in this car and want the added safety.
Moser pic attached
Car: 91 Camaro
cool, thanks! so, you just had the holes drilled in the mosers? I thought maybe you had found some lightened axles or something but this would be even easier!
Heres a sound clip of my car idling and revving. Ill get one of driving later on tomorrow. Video - 86' Chevy Camaro 2.8 V6 Glasspack in place of cat and a resonator tip.
really dosent apply since the turbo changes the whole ex tone but this is mine with the flowmaster on it
hmm just incase the sound isnt working heres a direct link to the vid on my webserver.it opens with realplayer and i think quicktime
http://lethal.ics-il.com/1.3gp
the quality isnt th ebest cause it was taken with a cell phone
Car: 1986 Firebird
Engine: 2.8 V6
Here's some old clips of mine: TomP's Firebird, exhaust sound clips
Car: 1991 Camaro RS
Engine: 3.1mpfi swapping in a 2.8mpfi
Axle/Gears: non-posi rear
heres my camaro, dont got no sound clips though, this sounds very good, 2 1/2 all the way through, no CAT, muffler at end. Sounds very nice, deep sounding like a V8 at idle, sorta rice-burner when revving.
Car: 1992 Firebird
Engine: 3.1L V6
bringing this thread back, seeing if there are anymore sound clips.
I dont know why DDR got banned, but Im sure it wasn't for no reason. The link he posted:
I wanted something like the bottom picture, but with dual exiting pipes and dual mufflers, but one cat. Anybody make something like this?
Still looking for some clips of magnaflow exhausts on a V6
So far, I love 69Charger383's setup alot, but I think that wouldn't be legal out here.
#42
Car: Formula/RS
Engine: 5.7L/60 degree
Transmission: both 700r4
Axle/Gears: 2.73 lsd and 3.23, respectively
Re: V6 Exhaust Sound Clips
#43
Car: 2002 Pontiac Firebird (R.I.P 1992)
Engine: 3.8L Ram Air V6 3800 Series
Transmission: 5spd
Axle/Gears: Unsure
Search my posts for a vid of my old exhaust...
Custom 3 inch magnaflow kit on the 3.1L made it sound BEASTLY!!! At idle it sounded like a v8, and stayed that way up to about 3000 RPM. Could feel and most DEFINATELY hear the improvements. Best upgrade I ever chose... So nice
Hotrodboba400
12-10-2019 07:07 PM
