oil pressure safety switch
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
looking to find out how many wires it has.
suppose to be near oil filter.
Does it have a 2 wire or 3 wire switch?
[not looking for the gauge switch.]
thing is AZ wants $40 for one and needs to order
found a few on Ebay long n short, 2-3 wire
Item number: 8026715513
Item number: 4614894586
Item number: 8038968094
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yanno... I just spent 10 minutes trying to dig up a full part number plus picture for ya..... and then I remembered how much of a complete pain in the *** you've been to me during and since my time as a moderator. Nevermind!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I was waiting to test that.
Its so nice when your forum settings work right.
I just wanna make things easy on me.
Book only shows two wires but ya never know.
Price vary from $9-$40 and I wanna order tonight.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
it should be the 2 wire. I broke the 3 wire one during the 305 swap and that's the bastard that's $40 to replace
1 Post
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Really glad I didn't bother
BTW napa only charges $34 for the "$40 one"
Car: 1986 Firebird
Engine: 2.8 V6
I only did that ignore feature with one guy on here... and I never checked on his posts, either. That's a memory for the old-timers here, huh?
Yeah it should be two wires.
Keep in mind too that it's not a real safety switch... it's more of safety as in "so your car doesn't die when you're merging onto a highway".
Go for a junkyard one!
And actually, you don't need it... I drove for years with mine disconnected. Why? Well when I put in my oil pressure and water temp gauges in my nifty new-for-1997 dual gauge pod, I thought the oil pressure safety switch was the gauge sensor. Yep, I unhooked/replaced the wrong one.
So a few years later when I realized I made a mistake, I removed and unhooked the correct gauge sensor, and hooked back in the "safety switch".
As long as your fuel pump relay's good, you're OK without GM's "safety switch".
Street Lethal
04-30-2019 12:14 PM
ambainb
04-25-2016 09:21 PM
