v6 fuel system
v6 fuel system
its an 86 with the 2.8v6. i was wondering how to relieve the fuel pressure in the lines so i can change the fuel filter...
im asking this for a friend...thanks alot
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Pull fuel pump fuse, start engine, let it run until it stalls.
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
You can also just let it sit overnight and the pressure will be down enough in the system that you can wrap a shop rag around the fuel filter fittings and use a catch basin under it. Not much gas comes out.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
fuel pressure guage to the schrader valve, and hit the reset button a couple of times.
Car: 91 Firebird
Engine: 191ci 6cyl
"Pull fuel pump fuse, start engine, let it run until it stalls." that somewhat worked for me but I still got shot in the face with tons of gas. Be careful.
1 Post
Car: Camaro
Engine: 3800
Oh it's not that bad... just unscrew it after its been sitting for a little while. Then again the way gas prices are... like an ounce of gas is like 600 dollars... so I can see why it'd be a problem wasting gas
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Best so far. You can just turn the schrader cap upside down, and hit the stem with it and a rag. Rag soaks up the gas and keeps it outta your face.
Screw the hard stuff with trying to find the fuse and start the car n crap. Geesh, you all do stuff the hard way
Engine: 350 S-TPI
I just find it easier to hit the scrader valve then to crawl under my dash, fight to get the fuse box down, then pull the fuse.
To each there own Aslong as you dont get an eye full of gas.
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
heh, when i replaced my fuel filter last, i decided i would just loosen the fittings at the filter enough to drain the gas out into an oil pan. . . but when i came back a while later it was still pushin out gas like a champ . . . i guess i had started a siphon because the opening was below the tank(woops!), so i ended up changing the fuel filter with gasoline dripping down my arms and all over me(i already had one end of the filter off, so it was get soaked and still have to change the filter, or change the filter and get more soaked. i only lost like 1.5 gallons of gas, but man i stung like a mother****er for twenty minutes after.
Engine: 350 S-TPI
Take the gas cap off first. Yes, you created a siphon, done this a few times myself.
Engine: 350 S-TPI
Raven, IIRC the gm manual says to hit the schrader valve on the fuel rail.
However, on the s10 TBI system, the only way was to pull the fuse, or reach under the bed and pull the plug to the pump, then start it.
Either way will accomplish the same thing.
9192camaro
16
02-03-2019 12:21 AM
Fast355
12-02-2016 06:33 PM
beachrodder
08-25-2015 08:05 AM
