brake booster vacuume canister question
1 Post
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i no longer have cruise control. the only other thing that runs off of the vaccume on that side of the plenum flange is the hvac controls. do they need the vaccume canister (orb of power) ? do the brakes need that canister? i beleave the check valve (pictured) prevents vacuume canister vaccume from going back toward the plenum, if i am right on this i should be able to remove that vaccume canister with no adverse effects on my braking system right?
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Yes, removing the "orb of power" will have no effect on your brakes. It may effect the HVAC controls though.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
does teh ord have jsut one nipple or two? (no beavis & butthead laughs please) if 2, then maybe run the hvac off of it. if one, then maybe secure one of teh squeare vacuum cannisters if you don't have one.
Engine: 5.7 / 7.4
right above the brake booster
ok, it's a rectangle from this view. My memory & spelling were off when I posted
Engine: 5.7 / 7.4
probably those w/o cruise
1 Post
Axle/Gears: n/a
well, this is odd. my car has a ceck valve, but it is capped off. i have mechanically oporated hvac controlls, so i capped the plennum "t" and chucked all that garbage
1992 Trans Am
05-10-2023 07:19 PM
