Whats the fatest tire we can run??????
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
quick what is the fatest tire's we can run with out rubbing in the front.,,.im asuming fater could be put in the back then the front
1 Post
Car: a car being parted out
Engine: blown up
Transmission: in peices
8's fit no problems.
sometimes 9's can depending on offset. (need to be pushed out a little more)
225/50's easy
235/45's are ok
245/40 might want to roll the fender lips...
225/50's easy
235/45's are ok
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
245/50/16s on 16x8 '87 IROC wheels here. No problems.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Sort of on topic
I was thinking about buying some winter tires only. But wanted to go tall and skinny. I wonder whats the tallest tire that would fit?
Maybe get a set of used 30' swampers for winter.
1 Post
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
keep in mind that if your car is lowered at all, even only an inch like mine, that it will decrease the width of tire you can put on.
Car: 85 Firebird
Engine: 2.8 MPFI
The left rear tire will rub against the filler tube cover inside the wheel well. So I removed it and sprayed Rust Check all over inside. We'll see if it rubs this winter....
The front tires have no rubbing problems since I have the heavy duty springs up front.
All my coil springs are new, so the car sits at stock height (and more in front). I would recommend one size smaller tires: 205/75R15.
Yea i got 205 75 15's in the back and in the fron im runnin i think there 205 65 15's piolets in the front..,., im guessing this is contributing to my poor handeling huh?........
Car: 91' Firebird
Engine: 3.1L V6
Axle/Gears: 3.23's
i'm running 235/55/15's and my fronts rub when i turn the wheel and it's taking less turning to rub lately
i really need to get some new struts/shocks
Car: 87 Firebird
Engine: Was 2.8, Now 350
Transmission: V6 T-5
Axle/Gears: 3.45 Open
ive got 235/65 R15 on mine...no prob...handled good 2 with 2 broken front springs...not so sure how it will work after v8 swap and ws6 springs....sits f*ckin high now
Car: 91 RS
Engine: 5.0 tbi
right now I got 235/60/15 on the front. and 275/60/15 onthe rear. when I drop in the v8 in the next month or 2 I will probably end up running 215/60/15 and maybe 295/60/15
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
EWWWWW..... HORRIBLE tire size! The front size is reasonable but thin....but the rear size....holy crap man, that's a really tall, rinky dink thin tire!
eightsixseven
08-14-2015 03:09 PM
