21 lb accel injectors
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I just had to replace the injectors on my 3.1. I stupidly purchased the 21 instead of the 15. They are already installed, and rather than having to worry about selling these off and buying the 15's I'd like to try and leave them in. Car idle's fine and accelerates nicely under normal throttle pressure, however, as soon as I go WOT the car bogs down and cannot regulate the fuel correctly. Has anyone used 21lb injectors, if so, did you get a custom chip for it?? I really would just rather make these work instead of going through the hastle of taking them out again.
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you HAVE to have a custom chip for that. part throttle will be fine but WOT will not. it is going very, very, very rich.
Car: 1992 Camaro RS
Engine: 3.1 V6
weeellll now that we're on topic, anybody want a set of new injectors. The price will be right. Alan, I know you're eyeing these puppies up, kretos my man, how would you like a new set of ACCEL injectors. I will start the bidding wars now!!!!!!
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
lol, even for the heavily moded 3.4 i'm building 21 is too much, i do however have a set of 15's that i could sell you, they would need to be cleaned by rich at cruzinperformance.com
Car: 1992 Camaro RS
Engine: 3.1 V6
Thanks for the offer but I'm going to see on the off chance that summit will allow me to exchange them. Thanks again for you help guys!
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
21lb/hr injector will support approx 33 HP x6 equals approx 200 HP.
I guess my 32lb/hr injectors that I need are just over kill.
Car: 91 Camaro
Car: 89 Iroc
Engine: lb9
Originally posted by The_Raven
So your "heavily modded 3.4" is going to make less than 200 crank HP?
Car: 1987 Trans Am
5.0 Mustangs (215-225hp) came with 19lb injectors, and they aren't an issue til around 300hp NA. Redraif's injectors are 19lb Fords out of a Crown Vic (cleaned by Rich), and even with a big cam and head work the car is still rich, and needed programming to clean things up. 21s would be good for a mild turbo application maybe. A boosted engine puts greater demand on the whole fuel system, including the injectors, so a much larger injector than NA is required, even at similar power levels...so no, I don't think 32lb injectors are at all overkill for Raven's app.
toronto formula
09-10-2015 08:31 AM
e3pres
09-09-2015 02:51 PM
