Old gauges to newer gauges
Car: 88 Camaro
Engine: 2.8
Transmission: 5 speed
has anyone swapped out gauges, from like an 88 to a 91? or whatever, i noticed a difference in the gauges at the junk yard, and i really liked the newer style. Has anyone done this and how hard is it?
1 Post
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
the only thing thit might be dificult is if you don't have guages. do you have idiot lights? if so there would be more work involved,. but since you have an 88 you have an electric speedo, so a newer cluster should be a direct swap.
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
It depends what years are involved. The newer wiring harnesses are different for the gauge cluster cars. This requires repinning the dash cluster connectors. The idiot light swapout can be done as well, but it is more work. The senders have to be installed for the temp, oil gauges, a tach wire has to be run from the coil circuit, and there's an issue with maintaining the battery/charging light. This light is part of a circuit on the waring light cars that tells the alternator to start charging.
Engine: 2.8 LB8 HO
Interesting. I think 1985 was the last Firebird gauge cluster that had a mechanical speedo.
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
i think firebirds went electric before camaros, or at least thats what ive heard. i heard birds in 87 and maros in 89 i think. i know for a fact that pre-87 firebirds are mechanical speedo though. maybe late 86 had electric, but other than that 87=electric speedo.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
86+ Firebirds were electric.
90+ for the camaro.
The entire dash shell is different for a 90-92 camaro you wont be able to just bolt it in, the metal mounts that are part of the body are also different between the 89 and prior vs. 90-92. The wiring would be the easy part.
90+ for the camaro.
86 and 90, wow, didnt think there was that big of a difference! just goes to show you how much better firebirds are.
Car: 93 240SX
Engine: LQ9
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
but the Firebird dash already looks better, there's nothing to improve upon. the comero dash,.....well,.....is a different story
Car: 93 240SX
Engine: LQ9
maybe so, but i have yet to see a thirdgen camaro that looks better than a firebird, regardless of what you say.
Car: 93 240SX
Engine: LQ9
See previous post before dash discussion, for reference please see sales numbers and compare
it has always been my opinion that the majority of the world has bad taste, so i rest my case.
