tapping lifter?
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
tapping lifter?
when i start my car (usually when its under 50 degrees outside) my engine taps..its kinda loud at 1st....then as it warms up it basically dissapears. but...i can still hear it a little bit. after driving it for like 15 mins its gone..i think its a tapping lifter. u guys had any experence with this, and if it is a lifter is it important to replace right away? its been doin it since it got real cold around oct. thanx..
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
what weight erl are you using??? thin it up just a bit & let the lifters pumpup a bit faster.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
dump a 16oz bottle of marvelous mystery oil in the oil. Or run some ATF in the oil to break up the sticky stuff. Thinner oil doesn't really help, getting a cleaning agent in there will.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If it was my car and it started doing that I would.
add half a quart of good ATF and a 16oz bottle of MMO.
Then drive n beat it for a good week. Take it up into red line for each gear often. Work the stuff around. You'll be a qurt over full, but ok.
Then change the oil hot.
Stuff will run like black water.
a quart over full on the stick cold wont hurt anything. As once the motor is running. All the little nooks n crannies, valley area, valve cover and so on, that quart over becomes about 1/4 of a quart over. No chance or risk of harm.
Yeah that's good advice.
ALSO GM oil supplement also helps, too.
PS expect a smoking tail pipe as this stuff is worked thru the system.
I also would not run to REDLINE EVERY GEAR
Why?
Try used valve springs & the age.
But the ideas are most sound & correct.
Why?
Car: 1985 iroc-z
yeah this is good advise thanx guys. i was hoping it wasnt a cupped lifter or anything. but...sorry...whats atf? or mmo...im somewhat new.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
MMO is marvelous mystery oil
MMO is in a red bottle, made for both your gas n oil.
Great stuff for both. I use it often in my gas. Smells good too.
COuld get a 32oz bottle, put half inthe engine, half inyour gas tank. It a good upper cyl lube and help the intake fuel pump last longer.
Car: 1985 iroc-z
lol, thanks, i'll get the mmo and ive already got some of alfs cousin. thanks for the advice
Fred SS
10-12-2015 11:27 AM
skinny z
10-05-2015 06:23 PM
TX-SleeperC5
09-24-2015 03:13 PM
dimented24x7
09-06-2015 03:51 PM
