Improving Fuel Economy on 91 Camaro RS
Car: 1991 Camaro RS
Engine: V6
Transmission: 5 spd manual
Hi,
I'm new to the forums here, and I own a 1991 Camaro RS V6. I'm currently a high school junior, and as such, do not have much money. I'm looking for ways to improve the fuel economy of the car. I really don't know much about car mechanics unfortunately, but desperately want to learn. I am at a loss on how to get better gas milage out of this fine car, but from what I've heard, I could get new air filters, aftermarket exhausts, specialized oil, etc. Any suggestions?
~Alex
~Alex
Car: 92 ' Camaro RS
Engine: 3.1 V6
Transmission: 5 spd
Welcome, I am new myself. But a good tune-up should do. Buy the Haynes repair manual. Helps a lot.
Or search for the 'TomP tune-up'.
https://www.thirdgen.org/techbb2/sho...t=TomP+tune+up
Car: 91 Firebird
Engine: 191ci 6cyl
TomP's tuneup https://www.thirdgen.org/techbb2/sho...ghlight=Tuneup
as far as spark plugs go get regular old AC Delco spark plugs. Do not get the bosch platinum 4+'s or anything fancy like that. Other then that follow that tech article and it's a great place to start.
welcome to the boards.
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
yep i have heard those 4+ do nasty things to cylinder heads
Car: 91 Firebird
Engine: 191ci 6cyl
I read into what spark plug to get probably a lot more then I should have and basically the +4's or whatever block air/fuel from getting to the spark. Your only gonna get 1 arch. I know I had'em in my car and when I went back to the reg ole copper ac delco's my idle smoothed and the car ran better. They went crappy after like 2 months in my car. The Ac Delcos I switched to are still good after probably too long.
Car: 1991 Camaro RS
Engine: V6
I already have the Chilton manual, is the Haynes one that much better? Also, how many more mpg's can I expect from a tuneup like this?
1 Post
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Another thing is make sure your tire pressure is up to par.Run a bottle of fuel system cleaner also.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
not f-body, but still v6 related. I put Bosche +4's & Bosche wires in my 95 blazer and increeased mpg by about 2~3 on road trips. Couldn't really notice any improvement in city driving, as it's a pig, but hope this helps some.
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
AC RAPID FIRES KICK A$$. Also get a underdrive puly for the crank and that will boost your MPG i went from getting 200 miles per tank to 300 per tank they have well paid for them selves.
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i'm still learning what are you talking about exactly with underdrive pully because if it helps that much i might as well do it too
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
I recently bought a 91 Camaro RS, 3.1L.
I installed AC Delco Rapid fires and auto-lite spark plug wires and it runs smooth. Does having original ac delco spark plug wires is better than aftermarket products?
The underdrive pully goes on your crank and alternator DONT USE THE ONE ON THE ALT it wont charge your car. But put the one on the crank and you will be good to go it basicly gives less rotaitng mass exactly how it works i dont know "somone help me here"
The autolight wires are good but mine kept melting at my #3 wire becasue of the EGR being right there got a set of msd never had a problem again.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Fast RS, your right on the crank pully. It helps on the rotational mass theory. Your spinning your accesorrys slower, freeing up some power.
I advise doing this when you replace your drivebelt because of age. I dont advise doing this out of "random".
Do the tomp tune up. (I say stick with basic delco plugs also)
Also, you have a 91 maro, the intake on them are crappy. Start hunting ebay or salveage yards for the 86-89 style "tpi" airbox. Then install it, you will have to do some minimal modifcations to the car, but not bad.
Keep tires inflated properly. Make sure your shocks are good. Keep any excessive weight out of the car that you dont use on regular basis, or emergency use.
Cat-back is expensive, and assuming since your still teenage, not alot of money to spend on "un-needed" items.
Someone on here installed a vacume guage inside the car, learned how to read it for max mpg use, and has well made their money back. But its not fun to drive as it says you should
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
What does an underdrive pulley do exactly? Where can I get MSD spark plug wires or should I go for AC Delco instead?
1 Post
Car: 91 Firebird
Engine: 3.1 V6
Underdrive pulleys are larger pulleys.Their larger so therefore they spin slower...supposibly freeing up horsepower it took the spin the smaller and heavier pulleys..Its mostly BS.You shouldent expect to see any power going to your wheels..MAYBE 4-5 at the FLYWHEEL.
Mine is actualy smaller then the stock pully and i noticed the car had more power on tap and better MPG.
You can get MSD wires from JEGS or Summit they run lile 40 bucks i think.
1 Post
Car: 91 Firebird
Engine: 3.1 V6
Which of your pulleys are smaller than stock? That means it is overdriving...Your MPG and Horsepower should NOT increase...that would just be against the laws of physics...lol
Smaller pulley=Faster spinning=more gas use=less power to wheels.
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
The only local auto part stores carry auto lite, bosch, some generic brand and if I go to the dealer, then theres AC Delco.
Are MSD special or something and what improvements they do?
1 Post
Car: 91 Firebird
Engine: 3.1 V6
1 Post
Car: 91 Firebird
Engine: 3.1 V6
Durability then, why sum people BS that they increase HP and stuf....
I like msd becasue those are the only wires that would not melt to my #3 cylynder and brake every 5 minutes. AC Delco wires are good as well didnt have a problem with them but they are more money then MSD. Call jegs to they can get you a price and tell you about them 1800 345 4545
1 Post
Car: 91 Firebird
Engine: 3.1 V6
Keep in mind a bigger pully will turn more per revoultion then a smaller one will keeping that in mind a smaller pully will turn the accessorys less per revoultion.
It doesnt matter how much it spins it..The Speed is what matters.
All i am going to say is i know what it did with my car with gas milage and power i should sell those on tv cuz i know they work. id probly make more moeny then the damn tornado that dosent work
1 Post
Car: 91 Firebird
Engine: 3.1 V6
Engine: 350 S-TPI
The crank pully is SMALLER
Any accessory pully should be LARGER
...to reduce rotational mass.
Wires, the MSD, and some others are made of different material which helps carry the current better. This helping provide better spark to the hole. Of course, the stock coil sucks, so in turn you should upgrade it as well.
Engine: 350 S-TPI
v6 uses same coils as the v8s
hypertech is most powerful 53-55k volts?
then msd 52k volts
few down is accel 43-45k volts
stock replacement.??
then msd 52k volts
colton_carlson
03-08-2019 12:21 PM
92camaroJoe
08-13-2015 06:07 AM
