strange squeeling bird noise
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
when i start up my car cold it makes a strange chirping noise coming from the ac compressor area...and it goes away after its heated up....any clues?
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
Sounds like it could be your fan belt is loose or worn. Check the tension I think you should olny have about a 1/2 inch of play on the belt.
Car: 92 firebird
Engine: 3.1 V6
Transmission: 5 speed manual
Axle/Gears: t5 and standary rear end
mine does that
on mine the noise is coming from the air/smog pump, when i had my exhaust fitted we didnt bother routing the pipe from the pump in to the exhaust not sure if this is your problem but its definatly mine.
Nick (uk)
Nick (uk)
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Hey, I have the same squealing bird noise. Excprt mine seems to be coming from the transmission. The trans also has made some other noises that frighten me at times. It is 1992 with the TH700-R4. Oh yeah, the engine has around 160,000 miles on it, and the transmission is stock.
Thanks,
Max
Thanks,
Max
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
myvmax1 Is it when your engine is cold and sounds like a chirping sound/squeek? If its not in gear does it still do it. If so you need to rebuild your distributor. In all honesty i would not worry about i have a new one to put in but havent gotten to it and mine has been doing this for about 4 years.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Re: strange squeeling bird noise
first you drive a firebird and you asking about bird noises fcomming from your car???
I mean come on duh!!!!
glad things worked out for you though with the belt
sjorgens
10-01-2015 07:54 PM
