Exhaust idea for 2.8v6: opinions? feedback?
Car: '89 Firebird
Engine: 2.8 v6
Folks,
I need a new muffler for my '89 bird--it's a 2.8v6 with the stock 2.5" dual outlet setup.
When I look at the rear exhaust, I see some needless complexity. Given that pressure comes in one side and must twist around to leave both sides of the the muffler, it can't be all too free-flowing.
So here's my idea. Rather than buy a Dynomax or a Flowmaster or a stock replacement and two new 90-degree exhaust pipes, what if I used a straight ****-tuner type muffler right off the intermediate pipe? Certainly, that'd be a much more freely-flowing system; it'd be easier to install too--just clamp it right on the end of the intermediate pipe. Best yet, the selection of import-tuner mufflers seems largely stainless steel and of higher quality than the american-turbo-sytle for less or equal money.
I think it'd tuck in there quite nicely--granted, that'd make the outlet sideways just behind the driver's side rear wheel rather than straight back, but I'd be okay with that.
Really, I'm worried only about the sound: would it just be IDIOTIC? Would people just crack up as I drove by? I mean, I'd be okay if it were tight, deep, and maybe even a little on the loud side. But I couldn't handle the whole import-fart tone.
What's the opinion? Worth a try? Or is the idea just totally baked?
Thanks, guys.
Thanks, guys.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
get a Raven muffler & use your idea right off the i-pipe. also weight savings
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
more flow, heck yea. After fixing many leaks in the stock system the hi Rs got slugish and not so free so I went with a free flow muffler.
Car: 1987 Pontiac Trans Am GTA, 1992 Chevrolet Camaro RS
Engine: Custom 350, 3.1 V6
Transmission: 700R4, 700R4
I've been toying around with this same idea for awhile. I've been wondering how our V6s would sound with one of those type of mufflers.
Car: 1986 Firebird
Engine: 2.8 V6
My guess is that it would sound like garbage... I've never heard one that sounded good.
TomJ23, actually most of the exhaust comes out of the driver's side pipe; it's not "forced" to split evenly to the passenger side pipe. You'd see that on a cold morning; you'll see more fog from the driver's side than the passenger side.
As far as longevity; I've had my current Dynomax super-turbo catback (#17493, Summit Racing # WLK-17493) on since 1998.
I had one from '96 to '98 but my rear passenger side hanger had fallen off, and the i-pipe was bouncing on the panhard rod- finally it cracked clean thru. I didn't have a welder back then so I just replaced the whole system- but aside from that crack, nothing had rusted thru.
So for longevity, to me, that's pretty good (6 years). I guess it won't last 100 years, but then again, neither will I.
Try your idea out; if it does sound like crap, then sell the muffler on Ebay.
Actually Summit Racing has a "handshake guarantee"; I wonder if they'd accept a used muffler if you told them it sounded like crap, and then used the store credit to buy another system off them. Give them a call and see, 800-230-3030 http://www.summitracing.com
Or maybe there's a used super-shiny-fart-can-style muffler up on ebay for cheap- even if it's dented, as long as it's cheap, you'd get a good idea on sound.
[edit] Actually, if your setup is 2.5", it's not stock. Stock was 2 1/4 inch for a V6's I-pipe (intermediate pipe, between cat and muffler) and I'm 99% sure the stock tailpipes were only 2.0 inch diameter.
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
TomP caught it - 2.5" isn't stock.
I'd suggest a simple Turbo muffler from Autozone, straight through. $18.
Car: '89 Firebird
Engine: 2.8 v6
Assembling an Exhaust system
Thanks, guys, for some superlative tech support. Indeed my 'bird must not have its stock exhaust system on, which leads me to more questions.
First, if I'm matching muffler to I-pipe with the stock slip-joint, do I buy a muffler with a matching input size? In other words, if my I-Pipe is indeed 2 1/4 inch, do I buy a muffler with a 2 1/4 inch input? Or do I have to compensate in some way for the pipe overlap in the joint? I.e., would I buy a muffler with a 2 1/2 input to be sure it'd slip over the 2 1/4 inch i-pipe? (1/4 inch of slipping space seems like an awful lot to me, but I thought I'd better ask the "duhh!" question and be sure.)
Second, wither I go fart-can, ravin' or Autozone $18 special (which is a suggestion most on-spot with my wallet--thanks again), would the passenger side I-pipe hanger be sufficient to support the muffler's weight? Given how close it is to the joint, I'm betting it'd be just right.
Thanks again, guys.
Thanks again, guys.
1 Post
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
its been done before.. this is a thread on superiroc's car, and he's got one on there.. scroll down and judge for yourself
https://www.thirdgen.org/techbb2/sho...import+muffler
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Different Idea for Exhaust...
I've been toying with an idea for the exhaust for a while now. But the biggest question I have about the idea is:
Is it actually possible to do a true dual exhaust system on a thirdgen? If so, would I end up mirroring the stock routing on the driver's side (there don't seem to be much room in the back once you hit the rear LCA mounts) or is it possible to run down the side of the car, just behind the pinch weld, assuming side exit exhaust and a muffler similar to Gumby's on each side?
I've been toying with this ever since I found out that a new exhaust system is in the works (y-pipe is literally broken in half and some @ss couldn't weld anything together worth beans... was that way when I bought the car).
I have the car up on jackstands for the winter and am looking for something to keep me occupied for the month until I have to return to Ohio for the next quarter at school, so time is not really an issue, but cost is... (out of state surcharge bites)
BTW, when I do end up replacing the exhaust, is there anyone on here that would like a slightly used, very dirty Flowmaster 80 series? The connections will end up being slightly messed up as I do have to cut through three welds to get the bugger off (some moron decided to weld everything behind the y-pipe/cat connection together... ), but I am willing to sell it cheap since it is used and no longer shiny like it was when new.
Car: 1986 Firebird
Engine: 2.8 V6
Re: Assembling an Exhaust system
If you have a way to check the end of your current intermediate pipe, somehow trace it on the end of a piece of paper, or measure both the inside and outside diameters with a ruler, and bring that to the store where you're buying the muffler from. Then you can check it right there at the store.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You wound me Tom. My car sounds good.
Though my whole exhaust is free flowing , no cat.
I actually enjoy driving without the radio on now. When before I use to crank it up just not to hear the whiny sounds of the stock system. All good deep tones with none of the V6 raspy sound.
I now enjoy rev'in it out more as it doesn't sound like a hondu coming.
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
maverick, there is a sticky on the exhaust boards regarding true dual exhaust systems on thirdgens...
https://www.thirdgen.org/techbb2/sho...hreadid=204351
Car: 1986 Firebird
Engine: 2.8 V6
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
How much difference in sound does the tip make?
I think within the next couple of weeks I am going to get one of those shiny "import" style mufflers with the dual tips and have it exit out the side. Haven't seen any Camaros around with an exhaust like that. Do you think it will sound any louder than my Flowmaster muffler?
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
just like any other brand of muffler, i'm sure there are quiet ones and there are loud ones...
I would assume they'd sound like a glass pack since thats what they basically are. Unless I'm mistaken.
Thornburg
08-25-2015 01:46 AM
