3.1 Heads on a 3.4 Block?
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Will it work? I can get the block for 200 dollars and the 3.1 heads i got in the garage are machined and port and polished with springs to match the cam. Will it work or will it suck?
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
IIRC, the heads are identical to begin with, so yeah, have a ball
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Not quite, but if you dont have one right next to the other, you cant tell the difference.
Go get that block.
theshackle
03-05-2017 06:37 PM
MoJoe
09-24-2015 09:12 PM
gixxer92
09-01-2015 04:32 PM
