Puddles of trany fluid again!
Car: 89 Firebird
Engine: 2.8 V6
Ok here we go again,
My car is dumping Trans fluid onto the garage floor again. Its like the 4th time its done this. I took the car back to the trans shop before my trip to Oklahoma they checked it out and all was good but was low a quart of fluid.
The Trans is still shifting fine and all and hasnt acted up again since they got the Tv cable adjusted and installed correctly on it, whyis it doing this any clues would be great
Donnie H.
Donnie H.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Jack it up and see where its leaking from.
After i did the v6 to v8 swap i had a tranny leak, Turns out one of the atf cooler lines had a pin hole.
HoosierinWA
10-07-2015 10:15 AM
