Smog pump ---> Supercharger?
Car: 2000 Trans Am WS6 (Black)
Could it be possible to, instead of removing the smog pump, to somehow use it to blow cold air into the intake? Maybe even create some boost? I have read on the internet that our cars come with the same smog pump that came on much bigger vehicles, but I'm not sure. I also read that these things can create high-pressure air-flow.
Also, people have told me over the years that cars with computers really need the smog pump due to programming in the ECU, is this true?
One other thing, I actually read about some guy who made a supercharger out of his A/C compressor, then he even had an electric clutch, because all you need to do is turn on the A/C, hehe .
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
An old VW trick is to use an early Buick smogpump belt driven to the crank of a pancake type1 motor and it would produce 3lbs pressure into the stock 34pic carb- but were talking a 1600cc motor.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
A smog pump would not even overcome vaccume.
Yes you can remove it from a CC car.
And this has been talked about before.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Sounds sort of like THIS Set up I'm looking into. On the Aussie boards, a guy w/aSeries I 3800 w/an afpr got some decent power. $1800 Austrailian is pretty good, just have to find the correct intake for it & see how much rapage shipping is
1 Post
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
How
How much is that in US currency? not to bad a deal, although, the boost is a little low.....I had that idea 3 years ago, AC clutch engaged SC...Blitz beat me to the copyright
Engine: 5.7 / 7.4
1,259.67 USD
http://www.xe.com/ucc/convert.cgi
They're engine specific for their kits, but I'm sure if you fab up a bracket & find some crank pullies............
page didn't work...
but it seems that 3 psi is kinda low... I would think you would want at least 5-8psi... if not more...
Engine: 5.7 / 7.4
Originally posted by ScrapMaker
page didn't work...
page didn't work...
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Dont forget that the stock smog pump uses hot engine bay air. Not outside cold air, and no good way to route it.
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
only thing useful you can do with the smog pump is get a kit to turn it into a vacuum pump and create a vacuum in the crankcase. it will help piston rings seal better and can produce as much as 20hp on a race engine but you're looking at very minimal gains on a stock engine. worth a shot if your hellbent on defeating emission controls that make the air your breathe better for no reason at all
Car: 1989 C4
Axle/Gears: 307
Actually you can make a smog pump a fresh air pump, just take the hose off the mnifold valve and route it up front. Would it be worth any power or the $8 of 3/4in hose is question.
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I also had the idea of an AC pump SC. I was thinking more along the lines of hooking it up to the intake before the MAF while leaving the stock intake there. Since my car has an AC bracket but no AC, it would be a supereasy set up. Maybe not a whole lot of gains, but worth the try.`
Engine: 350 S-TPI
actually, the smog pump sucks in engine bay air, and pushes it thru the exhaust.
I dont see how you can get fresh air into the intake with it
Car: 1989 C4
Axle/Gears: 307
No it sucks exhaust from the exhaust manifold/manifolds and directs it into the induction stream. It only does this in cycles though determined by temprature. I forget what the "exact" setup is on an injected 6 but a V8 for example has a temprature controlled vacuum switch either in the manifold or on the t-stat housing. This is activated by coolant temprature and allows full vacuum to reach the valve on the smog pump and it turns allows exh to be cycled through the induction system via the tubes on the exh manifold. Usually you can hear when the smog pump is activated by a humming/buzzing noise especially if the induction hose or air cleaner is off.
Now if you were to plug the exh manifold tubes off, route the 3/4 hoses to the front of the nose and pull the line fron the temprature controlled vacuum switch and install it to full manifold vacuum you would have a pump that sucks in fresh cooler air as long as the engine is running. I actually did this on my I6 bronco, cant say it did anything power wise but it dident suck hot air anymore.
Engine: 350 S-TPI
Sorry SSC, but my smog pump blows air thru the 3/4" pipe. And it never was hooked up to my intake system, other then the vacuum tube.
Now my EGR sucked hot exhaust air, and routed it into the intake.
Car: 85 firebird
Isnt it wonderful? Gm thought, hey lets blow hot exhaust air into the plenum and cooler air into the exuahst!
Originally posted by SSC
No it sucks exhaust from the exhaust manifold/manifolds and directs it into the induction stream...
edit: I see that Dale already said this.
Car: 1989 C4
Axle/Gears: 307
Actually smog pumps do both at least most GM pumps do. There are 2 valves one diverts exhast air into the engine the other takes fresh air some do take hot engine bay air and induct it into the cat. If you realy get into how certain things like smog pumps and EGR valves actually work and thier function durring the operation cycle its neat "trick" stuff.
What was this thread about? Turning small air pumps into superchargers? I wonder if you can see a little bit of improvement by forcing a small amount of extra air into the engine.
Car: 1989 C4
Axle/Gears: 307
Originally posted by camaro_junkie
I'm not so sure this is the case on my car, but I'll try and remember to check it out.
One day I gotta figure out how to take snapshots from M-O-D.
Anyway it shows the MPI for your year (86) has the standard 4 flanges. Of course it is controlled by the ecm so my early statement about using manifold vacuum to operate the valve to full divert "air to intake" GM speak (deceleration mode) would be a tad harder but still possible. In decel mode it diverts air into the inatake to prevent poping. It does this at high RPM and when the ECM detects a rich condition as well. So in essence it does force pressurized air into the intake like a supercharger durring the mentioned conditions but not all the time.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
so unless the intake is sealed off and all the air comes thru the blower, it isnt going to do a lick of diff..... it might as well be free wheeling in the air.
the very largest of pumps on the very smallest of motors, can possibly create some boost, but i doubt they are efficent, and some i dont think could contain pressure anyway....
Car: 87 SC
Engine: 2.8 MPFI
Some year smog pumps, the second valve doesn't divert to the cat. Mine's an 87 SC, and it just goes and blows it back into the engine bay once the engine has warmed up and it's not blowing it into the exhaust.
If, for some strange reason, you got the front of the pump to pull cold air from under or forward of the rad, and you just ran that second line to the intake instead of to a little can full of cotton and mesh... well. I'm not sure what the point would be. It's air, but it's not very forceful air.
toronto formula
11-10-2015 06:17 AM
