car sounds like plane
Car: 1990 firebird
Engine: 3.1 v6
well now that i riped off my hood insulator i have noticed that my car sounds like an airplane!, is it normal for me to hear some wind noise under the hood, it only happens when i push the gas, is this normal or is just a leak? i remember my cousins camaro sounding like this, im thinking its normal..am i wrong
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
could u give a better discription, like describing the sound and not using "like an airplane" cause that makes me think, 747, 767, C172? Hissing can be a vacuum leak, tapping can be an exhaust leak, how's the car performing?
Car: 1990 firebird
Engine: 3.1 v6
sorry if im not describing it correctly. it sounds like a high hissing sound when i rev up, would a sound clip be better?
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Ported vac leak, alternator whine, or you're hearing the air going past your throttle blade. Try to discern whether the sound is related to engine rpm or throttle position.
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
The MPFI V6's make a loud "whistle" draw through the throttlebody with the stock air snorkels off of them. That is normal.
Car: 1990 firebird
Engine: 3.1 v6
i think its more throttle related, only happens when i rev her up, i think it could be the air passing the throttle blade like you said, i have a video i just need someone to upload it unless you want me to send it to you guys,
aim: canito0
aim: canito0
