Viton vs. Teflon valve seals
Old 04-25-2004 | 08:21 AM
oil pan 4's Avatar
Car: 89 Firebird
There for my 11/32'' valve (Staineless steel) and .530'' valve guide cast iron heads.
It will have a no hotter than a 180 thermo, Mobil 1 oil, wet sump oiling, no valve stem cups, single spring with a spirl damper, .511'' lift, top engine speed of 6500 rpms, forced induction (TT's), direct port fuel injection (some fuel contact with intake valve stem), most likely be run a little rich, it should only pull about 20'' of vaccume and have a low $ engine crank case evacuation pump.
Teflon is said to be for race engines and viton is the better stock replacement.
What do you think I should run???
Viton or Teflon?
I have been to the Viton web site and seen all its specs when used as O rings and pump seals.
Teflon is teflon I use those seals all the time on hyd system seals to gas turbine compressor stage seals, many uses.
Old 04-25-2004 | 10:51 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Go w/the Viton. Even if it turns out to be overkill, you have that extra insurance & a good feeling in the back of your head.
Bubbajones_ya
07-06-2024 09:32 PM
gta892000
08-11-2019 12:16 PM
355tpipickup
09-14-2015 12:35 AM
bamaboy0323
09-12-2015 08:14 PM
tgp1990
09-04-2015 07:24 AM
